Community Member
BGP and RIB
Scenario:
Two data centers (Data Center A and B) in different states.
Company X owns x.x.1.0/24 and x.x.2.0/24 AS:1234
Data center A gets the full routing table for ISP1 and advertises x.x.1.0/24
Data center B gets DF only from ISP2 and advertises x.x.2.0/24
Issue:
Data center A is not getting x.x.2.0/24 from ISP2.   ISP2 does advertise x.x.2.0/24 but Company’s bgp peering router doesn’t see a route for x.x.2.0/24
ISP2 is sending x.x.2.0/route like this
  Prefix                  Nexthop              MED     Lclpref    AS path
* x.x.2.0/24         Self                                    444 555 1234 I
Question?
Is the reason why the wan rt peering with ISP2 not seeing the route to x.x.2.0/24 because it sees its own AS number in the AS-path?
Thank you in advance for your input.
Cheers!
1 ACCEPTED SOLUTION
Hi,You are correct. In this
You are correct. In this scenario, DC-A should see x.x.2.0/24 from ISP1, however, it should be dropped from its BGP RIB on receipt due to as-path attribute.
This is normal operation of BGP.
Community Member
Clarification TYPO!!! Issue
Issue:
Data center A is not getting x.x.2.0/24 from ISP1.   ISP1 does advertise x.x.2.0/24 but Company’s bgp peering router doesn’t see a route for x.x.2.0/24
ISP1 is sending x.x.2.0/route like this
Thank you!
19
