11-20-2006 06:10 AM - edited 03-03-2019 02:45 PM
hello everybody, is there solution when a bgp speaking router advertise route to ebgp peer, do not add local-as number,or add null as-number, in other means ,do not change the as-path attbribute to ebgp peer!
11-20-2006 06:16 AM
Jiangyi
I am not aware of a way to do what you are asking. And I do not understand why you would want to advertise a route to an EBGP peer without telling the EBGP peer what AS the route came from. They primary defense against routing loops in EBGP is to compare AS numbers and what you are suggesting would defeat this. Perhaps you can clarify what you are attempting to accomplish and we might find some way to accomplish it.
Rick
11-20-2006 06:34 AM
I kown the as-paht is primary defense against routing loops. if there is demand flow:" don't change route attribute that form AS xxx , to advertise these routes to AS YYY"(xxx\YYY are different as)
so i think , the next-hop\as-path and other attribute don't change. is there solution? or may be i misconceive.
11-20-2006 07:45 AM
11-21-2006 01:01 AM
"nei xx.xx.xx.xx local-as no-prepend" this feature not prepend local as number ,but also prepend local routing bgp process number. i want to prepend null as number to ebgp peer. however anyway ,thanks bella!
