BGP best path problem
julxu
I have setup something like, 1EBGP->1IBGP->2IBGP-2EBGP. and try to do best path selection.
I found what ever I set on 1EBGP for localpreference or metrix or comunity, to only pass to 1IBGP, not to 2IBGP. so, the problem is 1IBGP select 1EBGP and 2IBGP select 2EBGP.
do I have anywhere to fix this?
do I have to make direct neighbour between 1EBGP and 2IBGP?
any comments will be appreciated
Thanks in advance
julxu
11 Replies 11
Sergey Fer
LocalPref has local (inside AS) significance. You may set it for inbound (from eBGP peers) routes and it will be passed to iBGP peers.
MED by default is significant only between two ASes (the must be the same if you do not use bgp bestpath always-compare-med command).
Community (cost community for example) is different. You need to allow passing communities between neighbors first of all. And if you need cost community it will be AS-local significant.
You may use any topology and you may achieve neccessary result only by manipulating BGP attributes. I'm sure.
what I did is;
router 1EBGP:
router bgp 64650
bgp route-id 10.2.2.2
neighbor 111.111.111.111 remote-as 2222
neighbor 111.111.111.111 route-map default-in in
neighbor 111.111.111.111 route-map  mynet-out out
neighbor 10.1.1.1 remote-as 64650
route-map default-in permit 10
match ip address default-list
set local-preference 150
router 1iBGP:
router bgp 64650
bgp router-id 10.1.1.1
neighbor 10.2.2.2 remote-as 64650
neighbor 10.3.3.3 remote-as 64650
router 2iBGP
router bgp 65650
bgp router-id 10.3.3.3
neighbor 10.4.4.4 remote-as 64650
router 2EBGP:
router bgp 64650
bgp router-id 10.4.4.4
neighbor 555.555.555.555 remote-as 2222
neighbor 555.555.555.555.road-map default-in in
neighbor 555.555.555.555 road-map mynet-out out
road-map default-in permit 10
   set localpreference 200
the result is
the router 2iBGP get defult route from 555.555.555.555, and 1iBGP get default route from 111.111.111.111.
it should be both 1iBGP and 2iBGP all get default from 555.555.555.555 because I have set local preference 200 here.
how can I get the both (1iBGP and 2iBGP) get default from 555.555.555.555?
Please advice
julxu
Could you send your topology map. Without it and with faked IP addresses your config is not so clear... What is AS 2222, IPs 111.111.111.111 and 555.555.555.555?..
briefly draw something, hope it can be seen.
the problem is the local preference can automatically go to the neighbour, but can not go next hop, so the next ibgp router, even in same AS, will not get the local preference, it thi
the as 2222 is BGP AS, and both 111.111.111.111 and 555.555.555.555 are inside AS 2222, but not at same location.
in diagram, you can see, it is r from of the route, because I have to put a static route to force both 1iBGP and 2iBGP all go to same direction.
please advice
Julxu
Well, first of all you need to set up any IGP in your AS 64650 (it may be static though).
Second. 1iBGP never get routes obtained by 2eBGP because of iBGP nature (same thing about 2iBGP and 1eBGP). BGP router DOES NOT send any iBGP route to any of it's iBGP peer. You need to make route-reflection or BGP confederation to ovverride this. You may make 1iBGP and 2iBGP route-reflector-clients of each other and eBGPs - clients of correspondent iBGPs.
ok first,
as you suggest, add router eigrp on 1ibgp and 2ibgp:
eigrp 1
redistribute bgp 64650 metric 5000 10 255 1 1500 route-map permit-default.
or
redistribute bgp 64650 metric 10000 100 255 1 1500 route-map permit-default.
tried put but one of redistribute statement into one box and another into another box.
but, it do not seems work, it looks like the if one take the default, and another one will put r in front.
No, no, .... Don't do redistribution. IGP is for iBGP to work properly. Mainly - for NEXT HOP attribute to be correclty recognized because of the fact that NEXT HOP is not changed during iBGP transmission.
the NEXT HOP means "next-hop-self"? if so, it is in the configuration already, if not, please advice how to do it.
basically, I want 1ibgp and 2ibgp can see two routes, not only one.
Many Regards
Julie
NEXT HOP is an attribute of every route in BGP. Because of the fact that NEXT HOP in BGP may be far far away of the router that receives route, it (router) needs to have NEXT HOP in it's routing table for route recursion to implement. NEXT HOP changes in eBGP peering, it does not change in iBGP peering. Therefore if 1eBGP gets a route from AS2222 that route has NEXT HOP equals to IP address of AS2222 router. When 1eBGP send that route to 1iBGP NEXT HOP does not change and hence 1iBGP does need to have it in it's routing table (through any IGP for example). If you use next-hop-self in neighborship between 1i and 1e (it must be configured on 1e) than you change NEXT HOP to be an IP address of 1eBGP and here you do not need any IGP. But you also need to do the same thing in ALL iBGP neighbor statements.
Next. When 1iBGP receves a route from 1eBGP through iBGP it will not send this route to another iBGP peer (2iBGP) because of iBGP nature. Here you need to implement route reflection or confederation.
If you need more explanation, please let me know. I'll to do my best
for the second. I tried to put "bgp confederation peers " it says 64650 local memeber-as not allowed in confed peer list.
I guess, I need totally reconfig every thing to make AS as small as possible, right?
if I want do it, what I should do? I am not very clear what I should do, please advice
Many Regards
julxu
Well, confederation is bit tricky. If in normal situation your AS is 64650, in confederation it would be another. For example, you need to configure
router bgp 65001
bgp confed id 64650
bgp confed peers
