BGP community ignored for ospf route-map
I am receiving BGP routes, and want to set OSPF tags on them, based on BGP standard community. However in my test lab 2 communities are untagged (144.180.10.0 and 194.43.10.0) and one is community tagged in BGP (138.124.10.0).
The first route-map line should match the 144:200 tag in 138.124.10.0 and set OSPF tag of 190. However it seems to ignore the match community and all routes with/without community match route-map TEST permit 10, and all have tag 190 set on them.
Is this a bug?
Should this work?
Am I doing something wrong?
Thanks in advance.
router ospf 1
redistribute bgp 3246 subnets route-map TEST
network 155.209.182.139 0.0.0.0 area 0
network 192.168.13.1 0.0.0.0 area 0
router bgp 3246
neighbor 88.131.176.212 remote-as 65021
neighbor 88.131.176.212 send-community
ip classless
ip community-list 90 permit 144:190
ip community-list 91 permit 144:200
match community 91
set metric 3
set tag 190
route-map TEST permit 20
match community 90
set tag 190
route-map TEST permit 30
song#sh ip bgp
BGP table version is 4, local router ID is 192.168.13.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 138.124.10.0/24 88.131.176.212 0 65021 12641 i
*> 144.180.10.0/24 88.131.176.212 0 65021 12641 i
*> 194.43.10.0 88.131.176.212 0 65021 12641 i
song#sh ip bgp 138.124.10.0
BGP routing table entry for 138.124.10.0/24, version 4
Paths: (1 available, best #1)
Not advertised to any peer
65021 12641
88.131.176.212 from 88.131.176.212 (88.131.176.212)
Origin IGP, localpref 100, valid, external, best, ref 2
Community: 9437374
song#sh ip bgp 144.180.10.0
BGP routing table entry for 144.180.10.0/24, version 2
65021 12641
song#sh ip bgp 194.43.10.0
BGP routing table entry for 194.43.10.0/24, version 3
65021 12641
song#sh ip o d e
OSPF Router with ID (192.168.13.1) (Process ID 1)
Type-5 AS External Link States
LS age: 1134
Options: (No TOS-capability, DC)
LS Type: AS External Link
Link State ID: 138.124.10.0 (External Network Number )
Advertising Router: 192.168.13.1
LS Seq Number: 80000001
Checksum: 0xEB7E
Length: 36
Network Mask: /24
Metric Type: 2 (Larger than any link state path)
TOS: 0
Metric: 3
Forward Address: 0.0.0.0
External Route Tag: 190
LS age: 1134
Link State ID: 144.180.10.0 (External Network Number )
Checksum: 0xFA31
Length: 36
Network Mask: /24
TOS: 0
Metric: 3
LS age: 1135
Link State ID: 194.43.10.0 (External Network Number )
Checksum: 0xE0A2
Length: 36
Network Mask: /24
TOS: 0
Metric: 3
Re: BGP community ignored for ospf route-map
Just like you said all three routes are matched against your 1st route map statement, sets a metric of 3 and sets a route tag of 190 and redistributed into OSPF.
Based on that it appears all 3 routes are matching the community list 91. Can you add the global config command 'ip bgp-community new-format' and do a sh ip bgp 138.124.10.0 for the router to display the community in new format and that would help us verify the above assumption
Hoe that helps!
Sundar
Anonymous
N/A
Anonymous
N/A
Anonymous
N/A
Anonymous
N/A
266
