BGP community translation
is it possible to translate communities on incoming BGP updates like this.
ip community-list expanded TRANSLATE permit 1:2020
route-map TEST permit 10
match community TRANSLATE
set community 123:2020
I have tried seting this route-map on the input side and output side, but it doesnt seem to work.
Is there some other way to do this
1 REPLY
Hall of Fame Super Silver
Re: BGP community translation
Hello Armin,
you need to apply the route-map on the neighbor session inbound but be aware that so doing you are filtering all other possible prefixes.
I would suggest to add an empty second block
route-map TEST permit 20
if you want you can add your community to the other one using the option additive
3) verify if the advertisements have already multiple communities values the extended community ACL can have two modes : exact match or if one of the values match.
Hope to help
Giuseppe
308
