Community Member
BGP conditional advertisement feature
While using the BGP conditional advertisement feature, if I have 2 entries on the BGP table will the condition work only for the best path or secondary path can be matched as well.
Network Next Hop Metric LocPrf Weight Path
*> 0.0.0.0 1.1.1.1 0 0 400 i
* i 2.2.2.2 0 100 0 200 i
can I use
route-map test permit 10
match ip address prefix-list Default-Route
match ip next-hop 2.2.2.2
-Sai.
1 REPLY
Hall of Fame Super Silver
Re: BGP conditional advertisement feature
Hello Sai,
only for the best path I think in this case the IP BGP next-hop is 1.1.1.1 for the best path.
you can also use a route-map made of two blocks:
match ip next-hop 1
route-map test permit 20
match ip next-hop 2
access-list 1 permit host 1.1.1.1
access-list 2 permit host 2.2.2.2
note:
match ip next-hop
Redistributes any routes that have a next hop router address passed by one of the access lists specified.
or also
match ip next-hop 1 2
Hope to help
Giuseppe
206
