BGP Conditional advertisements Scenario config request
fortis123
Hi All,
Can you please shoot me a link to an config scenario to use Conditional advertisement.
2 nternet routers, Dual ISP (rtr1-ISPA, Rtr2 -ISPB ), having our own AS# and class C N/w being advertised and EBGP with both carriers.
Wanted to run Primary/backup autofailover.
Carriers not supporting Communities.
All the config exaples iam seeing is with single router with multihomed.
Thank you in advance
MS
Rick Morris
Level 6
Level 6
Ok, you have 2 routers...
How are they connected to your ISP's?
You can run HSRP between the two routers.
Then run BGP between your routers and the ISP and weight the traffic on the second router by prepending the AS.
There are other ways but this appears to me to be one of the simplest forms to do what you want. All traffic inbound will prefer the router with the lowest AS Hops, once the peer session is dropped then the second router will assume routing. In the HSRP you would want to track the serial link.
Here is the exact Scenario:
(considering 1.1.1.0/24 is our own RIPE assigned public space...)
RTR-A: 10MB Fast Ether to ISP-A
router bgp 42460
no synchronization
bgp log-neighbor-changes
network 1.1.1.0 mask 255.255.255.0
network 10.10.10.4 mask 255.255.255.224
neighbor 213.10.96.48 remote-as 21530
neighbor 213.10.96.48 ebgp-multihop 255
neighbor 213.10.96.48 remove-private-as
neighbor 213.10.96.48 soft-reconfiguration inbound
neighbor 213.10.96.48 distribute-list 15 out
neighbor 213.10.96.49 remote-as 21530
neighbor 213.10.96.49 ebgp-multihop 255
neighbor 213.10.96.49 remove-private-as
neighbor 213.10.96.49 soft-reconfiguration inbound
neighbor 213.10.96.49 distribute-list 15 out
no auto-summary
Fast Ether 0/1
descruption : LAN
ip address 1.1.1.2 255.255.255.0
standby 10 1.1.1.1
standby 10 preempt delay minimum 60
standby 10 priority 155
standby 10 track fast 0/0
distribute-list 15 : has ACL permits 1.1.1.0/24 and other /28 range to ISP-A
RTR B to ISP-B : 2MB via Serila0/0
router bgp 42460
no synchronizartion
neighbor 229.23.50.157 remote-as 6466
neighbor 229.23.50.157 next-hop-self
neighbor 229.23.50.157 soft-reconfiguration inbound
neighbor 229.23.50.157 route-map set-as-path out
ip prefix-list ISP-B seq 10 permit 1.1.1.0/24
ip prefix-list ISP-B seq 20 deny 0.0.0.0/0 le 32
route-map set-as-path permit 10
match ip address prefix-list ISP-B
set as-path prepend 42460 42460 42460 42460 42460
inter fast 0/1
description: LAN
Fast Ether 0/1
descruption : LAN
ip address 1.1.1.3 255.255.255.0
standby 10 1.1.1.1
standby 10 preempt
standby 10 priority 150
______________________________________
When I ran the test with some down time, it was observed that
1. when ISP-A link fails, it took 4-5mins for the internet to failover to ISP-B.
2. Also, when ISP-A is active, the traceroute from my PC to the public IP at this location, taking ISP-B path.
So after careful reviews, we observerved..
a) synchronization diff in both our local rtrs b) there may be IBGP required between both rtrs c) AS Path Prepend is not 100% perfect solution for primary/back up solution.
We might go with Communities or Conditional advt.
As my ISP-B does not support communities, Iam thinking of Conditional advt.
So iam looking for confg example with 2 rts, 2dual ISPs.
Thank you
MS
Also, as rtrs residing outside of firewall and not communicatiing with any internal IGP (in LAN), do I still need IBGP between these routers..? or the configs I mentioned are sufficient..?
Please suggest.
MS
Hi all,
Any suggestions are welcome & appreciated for Conditional advt.
Thank you
MS
Configuring and Verifying the BGP Conditional Advertisement Feature
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a0080094309.shtml
-Sai.
