Community Member
BGP-confederation
Hi ,
I am about to setup a confederation set up in my datacenter environment.Im in need of some clarifications.
Current setup details.
In a single ibgp domain 5 rtrs are there .2 rtrs will be seperated and configured as a private as.
1. Is it ok if a confederation behind ibgp(ibgp router will have direct connectivity with internet)
2.How the translations will happen?is there any standards for configuring confederations?any documents , links would be helpful.
3.can i get load balaning or sharing with ibgp peer from the confederation without any issues?
4.any other design considerations would be helpful.
1 REPLY
Re: BGP-confederation
With only 7 routers you probably will be better off just using route reflectors.
In confed setup you specify local sub-AS (router bgp X), confederation member AS (bgp confed peers ) and your AS seen to outside world (bgp confed ident Y).
Have a look here - http://www.cisco.com/univercd/cc/td/doc/cisintwk/ics/icsbgp4.htm
90
