07-16-2009 06:20 AM - edited 03-04-2019 05:27 AM
Here is the customers L3 Switch - What am I missing here? Let me know if more info is needed.
interface GigabitEthernet0/3
ip address Other Provider IP B.B.B.170 255.255.255.252 secondary
duplex auto
speed auto
media-type rj45
negotiation auto
router bgp ##AS##
no synchronization
bgp log-neighbor-changes
network x.x.x.x
neighbor B.B.B.169 remote-as ##B's AS##
neighbor B.B.B.169 description Primelink
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 B.B.B.169
ip route 0.0.0.0 255.255.255.255 10.1.1.0
no ip http server
no ip http secure-server
ip as-path access-list 1 permit ^##B'sAS##$
logging alarm informational
access-list 10 permit X.X.X.X 0.0.255.255
access-list 101 permit tcp any any
access-list 101 permit udp any any
access-list 101 permit ip any any
route-map AS-B'sAS-INCOMING permit 10
match as-path 1
route-map AS-B'sAS-OUTGOING permit 10
match ip address 10
route-map AS-15320-OUTGOING permit 20
match ip address 20
07-16-2009 06:40 AM
Hi Gabrielle,
Any special reason you make the interface IP address secondary? Also, what are you trying to accomplish with this static route?
I don't see your as-path access-list and route-map applied inside the BGP process.
jerry
07-16-2009 07:41 AM
I am trying to help this customer get this up and running. I have another static that was for testing on the interface that is why it is secondary. Also, I am not sure why he has this route of 10.1.1.0.
07-16-2009 07:45 AM
Hi Gabrielle,
You might have problem with the BGP peering section since the BGP peering will use the primary IP address. Beside that, this is the only issue I am seeing so far.
HTH,
jerry
