10-27-2010 07:27 PM - edited 03-04-2019 10:17 AM
Greeting
I have a bgp router, and it has more than one connections. they looks all can send whole routing table to the neibour without problem. However, I have just configure a new one with private ip address 10.10.10.248/30. the porpose is to send a class B address route to another end.
unfortunately, I have no any route-map and prefix list, but it only advice the default route 0.0.0.0 out, not public addrese route.
the configuration just simple at:
another end (the related configure)
router bgp 64500
no synchronization
bgp log-neighbor-changes
neighbor 10.10.10.249 remote-as 64500
neighbor 10.10.10.249 next-hop-self
neighbor 10.10.10.249 soft-reconfiguration inbound
no auto-summary
my end (the related configure)
route bgp 64500
no synchronization
bgp bestpath med missing-as-worst
network 10.10.10.248 mask 255.255.255.252
neighbor 10.10.10.250 remote-as 64500
neighbor 10.10.10.250 transport path-mtu-discovery
neighbor 10.10.10.250 next-hop-self
neighbor 10.10.10.250 soft-reconfiguration inbound
if I do ip bgp neighbor 10.10.10.250 advertised-routes, it give me only 0.0.0.0 and 10.10.10.248. the rest routes all can not be advertised.
It realy confuses me. I have a list of public addresses, but, for some reason they can no be send to another end without no reason.
Any comments will be appreciated
Thanks in advance
julxu
10-27-2010 10:50 PM
I see that you have an iBGP connection with this neighbor. Are the BGP routes that should be advertised to this new neighbor learnt from other iBGP neighbors?
Atif
10-27-2010 10:57 PM
Atif
great thanks for your reply.
yes, you are right, it is learned from other ibgp router. basically, I want private 10.0.0.0/8 and my public address route to pass to another router. not default 0.0.0.0.
is it possible?
julxu
10-27-2010 11:09 PM
julxu wrote:
Atif
is it possible?
julxu
You need to understand that a BGP speaker will not advertise any route it learnt from an iBGP neighbor to another iBGP neighbor. This is as per design and is done to prevent loops. Proper way of addressing this is to have a full iBGP mesh or use scaling approaches like route reflectors / confeds. If this is the behavior you are seeing then this is normal and you need to consider that in your BGP design. If there is additional complexity to what you are seeing then please elaborate the problem and provide as much detail as possible so someone can assist you.
Atif
