BGP default goes disappeared sometime
This is an ADSL atm network using a 2811 router.
My atm port is 10.15.254.2, edge router is 10.15.254.1
1. Every once a while the B* 0.0.0.0/0 [20/0] via 10.15.254.1, 6d20h default route would go disappeared, so BGP would change to Active.
2. show inteface bri said, atm 0/0 was up/up
3. I connected to the router through the back door, found out, the atm 0/0 port is not pingable.
4. To resolve the issue, I would need a shut/no shut on the atm 0/0, BGP would be reestablish, and it would work for 5-15 days.
Here is my normal routing table
C 10.56.0.0/13 is directly connected, FastEthernet0/0
C 10.15.254.10/32 is directly connected, Loopback0
C 10.15.254.0/30 is directly connected, ATM0/0/0
B 10.15.254.0/24 [200/0] via 0.0.0.0, 6d20h, Null0
C 10.15.254.128/25 is directly connected, GigabitEthernet1/0
=====show log when default route disappear==
Oct 6 11:01:36.330 CDT: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.152
.254.2 on interface ATM0/0/0
Oct 6 11:01:45.219 CDT: %LINK-3-UPDOWN: Interface ATM0/0/0, changed state to do
wn
Oct 6 11:01:46.219 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0/
0, changed state to down
Oct 6 11:02:05.223 CDT: %LINK-3-UPDOWN: Interface ATM0/0/0, changed state to up
Oct 6 11:02:06.223 CDT: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0/
Oct 6 11:02:06.351 CDT: %PIM-5-DRCHG: DR change from neighbor 0.0.0.0 to 10.15
Oct 6 11:02:07.919 CDT: %PIM-5-NBRCHG: neighbor 10.152.254.1 UP on interface AT
M0/0/0
Oct 6 11:03:52.922 CDT: %PIM-5-NBRCHG: neighbor 10.15.254.1 DOWN on interface
ATM0/0/0 non DR
ATM0/0/0 is up, line protocol is up
Hardware is HWIC-DSLSAR (with Alcatel ADSL Module)
Internet address is 10.15.254.2/30
MTU 4470 bytes, sub MTU 4470, BW 512 Kbit, DLY 1000 usec,
Encapsulation ATM, loopback not set
Encapsulation(s): AAL5 AAL2, PVC mode
23 maximum active VCs, 256 VCs per VP, 1 current VCCs
VC Auto Creation Disabled.
VC idle disconnect time: 300 seconds
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 6d07h
Queueing strategy: Per VC Queueing
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
984032 packets input, 500586163 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
838225 packets output, 106313349 bytes, 0 underruns
There are several hundred routers having the same problem lately which connected different ISP.
I think there are 3 ways to drop default route route
A. My NIC has problem.
B. The DSLAM has problem on 10.15.254.1
C. IOS has changed about 8 weeks ago. I am using Version 12.4(13r)T
D. I am planning to add a static route with AD = 21, hopefully, the static would connect to ISP, when default is gone.
Anyother suggestion?
1 REPLY
Bronze
Re: BGP default goes disappeared sometime
What you can see is that, during the failure, the 0.0.0.0 has disappeared from the 'sh ip bgp'!! This shouldn't be possible, because you are learning teh default from a eirgp neighbor. The 0.0.0.0 entry in the routing table hasn't been flushed for hours!!
http://www.cisco.com/en/US/docs/ios/12_1/iproute/command/reference/1rdbgp.html
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009425c.shtml#t1
178
