07-04-2014 09:01 PM - edited 03-04-2019 11:17 PM
Got a change last night to remove the advertisement of default route to Telstra(cqdnsopr01c10) as they have mentioned that they are receiving 0.0.0.0 from (HIDCSR01).
BGP Config of HIDCSR01
router bgp 64633
no synchronization
bgp log-neighbor-changes
timers bgp 7 21
redistribute connected
redistribute static route-map REDIST_STATIC
neighbor 10.88.128.89 remote-as 64632 // BGP Peer Telstra
neighbor 10.88.128.89 description Telstra Managed Router
neighbor 10.88.128.89 soft-reconfiguration inbound
neighbor 10.88.128.89 prefix-list NO_DEFAULT_ROUTE out//Prefix list added to prevent default route advertisement
neighbor 10.88.128.89 route-map LOCAL_PREF_200 in
no auto-summary
p prefix-list NO_DEFAULT_ROUTE seq 1 deny 0.0.0.0/32
ip prefix-list NO_DEFAULT_ROUTE seq 2 permit 0.0.0.0/0 le 32 ·
after doing the above prefix list, Telstra can still see the default route on their end, I tried checking the advertised BGP routes to them but I couldn’t see any 0.0.0.0 being advertised and there’s no default originate configured on that peer. · Redistribute static also has a route map in place which prevent default route from being redistributed.
BGP received routes from Telstra(cqdnsopr01c10) cqdnsopr01c10#show ip bgp neighbor 10.88.128.90 received-route
BGP table version is 127374, local router ID is 10.88.129.25 Status codes: s suppressed, d damped, h history, * valid, > best, i - internal, r RIB-failure, S Stale, m multipath, b backup-path, x best-external, f RT-Filter, a additional-path Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path r> 0.0.0.0 10.88.128.90//quuhidcsr01 0 0 64633 i ·
Not sure why it is still advertising even with the prefix list and where is it coming from. ·
Would it be better to have them filter the default route on their end?
07-04-2014 11:12 PM
07-05-2014 12:16 AM
07-05-2014 06:45 AM
is there any other routing protocol running between them. "r> 0.0.0.0 10.88.128.90" doesn't these show the default routes are advertised by some other routing protocols.can you do show ip route and confirm it.
regards
Prajithtr
07-05-2014 06:53 AM
Hello.
Your prefix list in not precise.
It should be
ip prefix-list NO_DEFAULT_ROUTE seq 1 deny 0.0.0.0/0
instead of ip prefix-list NO_DEFAULT_ROUTE seq 1 deny 0.0.0.0/32
PS: also I would suggest to use route-map to filter outbound updates instead of simple prefix list (just for convinience).
07-05-2014 08:41 AM
07-05-2014 08:43 AM
07-05-2014 09:47 AM
Hello.
0.0.0.0/32 is a host route to 0.0.0.0 IP-address.
0.0.0.0/0 is a default gateway.
For your configuration you need:
ip prefix-list NO_DEFAULT_ROUTE seq 10 permit 0.0.0.0/0 le 32
07-06-2014 07:39 AM
Hi vasili,
thanks!
like so?
07-06-2014 07:55 AM
Hello.
In your case another AS is sending you default gateway (check it - sh ip bgp 0.0.0.0/0). And you AS is just a transit, so you don't need default-originate to send default gateway further.
07-06-2014 09:44 PM
Hi vasili,
i dont have 0.0.0.0 in my bgp routing table when i use show ip bgp 0.0.0.0/0.
what i have is just a static default route but not redistributing to bgp so not sure why they are receiving this from us.
07-06-2014 07:35 AM
