12-13-2011 03:41 AM - edited 03-04-2019 02:36 PM
In that location cisco1841 router with two ISP with BGP.
One ISP is BSNL BGP and another one is TATA BGP. Both ISP have a seperate BGP AS number.
BSNL is connected in serial port and TATA is connected in Fast ethernet port.
We are using BSNL as primary and TATA as Backup.When BSNL line is down means it takes route to TATA.
Butafter the BSNL line came means and it is not take automatically switchover from TATA to BSNL.
what is the solution.
can any one help me.
12-13-2011 04:40 AM
are you using Provider independent addressing and your own AS ?
Can you post your config?
Regards.
Alain
12-13-2011 07:53 PM
This is My configuration
In this configuration how to get a fallover
Please send the configuration.
interface FastEthernet0/0
description ***** LOCAL LAN *****
ip address 10.10.70.100 255.255.254.0
ip accounting output-packets
ip flow ingress
ip virtual-reassembly
duplex auto
speed auto
keepalive 1000
interface FastEthernet0/1
description *** TATA WAN LINK ***
bandwidth 512
ip address 10.60.178.5 255.255.255.252
speed 100
full-duplex
keepalive 1000
interface Serial0/3/0
description *** BSNL WAN LINK ***
bandwidth 2048
ip address 192.168.48.7 255.255.255.252
encapsulation ppp
no keepalive
no fair-queue
router bgp 75001------>our own AS Number
no synchronization
bgp log-neighbor-changes
network 10.10.70.0 mask 255.255.254.0
neighbor 10.60.178.4 remote-as 4855---------->TATA AS Number
neighbor 10.60.178.4 soft-reconfiguration inbound
neighbor 10.60.178.4 route-map EBGP-TATAWAN out
neighbor 192.168.48.8 remote-as 9839------------>BSNL AS Number
neighbor 192.168.48.8 description ***EBGP Peer to BSNL***
neighbor 192.168.48.8 soft-reconfiguration inbound
neighbor 192.168.48.8 route-map EBGP-BSNLWAN out
no auto-summary
ip prefix-list BSNL-LANROUTES seq 10 permit 10.10.70.0/23
ip prefix-list TATA-LANROUTES seq 10 permit 10.10.70.0/23
route-map EBGP-BSNLWAN permit 10
match ip address prefix-list BSNL-LANROUTES
route-map EBGP-TATAWAN permit 10
match ip address prefix-list TATA-LANROUTES
12-13-2011 05:27 AM
" I have one problem in one of my Network setup.
In that location cisco1841 router with two ISP with BGP."
Does this mean that you have your own pubic AS number (or an agreed private as with both ISPs), or are you using the neighbor xx.xx.xx.xx local-as option?
what is the solution."
From the sounds of the issue it looks like you are not manipulating BGP at all, the easy way for you to do this would be to use Cisco Weight attribute on your primary link
Neighbor xx.xx.xx.xx weight
For growth I would recommend terminating each BGP connection on seperate routers establishing a iBGP session between them, and set the local preference on the BSNL router to anything higher that 100, this way you will get a AS wide AS exit preference
I would have a good read of this,
http://www.cisco.com/image/gif/paws/26634/bgp-toc.pdf
Cheers Neil
12-13-2011 09:18 PM
what weight value i give to primary link.
12-14-2011 01:06 AM
The default weight is 0, I usually increment by 100's
neighbor 192.168.48.8 weight 100.
Then
# clear ip bgp 192.168.48.8 soft in, this will refresh you BGP table.
Neil
