03-23-2009 02:39 PM - edited 03-04-2019 04:03 AM
All,
I looked in the feature navigator, and if I'm reading this right, it looks like BGP is in the 12.4(24) version of IP-Base. Is this true? I've already loaded it on a router, and I've got the router scheduled to reboot later tonight, but I wanted to see if I was reading the feature navigator right.
John
Solved! Go to Solution.
03-23-2009 02:58 PM
John
If you mean 12.4(24)T then yes it would appear from Feature Navigator that it does support BGP ie. you are reading it right.
Jon
03-23-2009 02:49 PM
John
Which device are you loading it on ?
Jon
03-23-2009 02:50 PM
It's a 2821
03-23-2009 02:58 PM
John
Jon
03-23-2009 02:59 PM
Perfect! I'll know more tonight. I changed my boot string, and I've got it scheduled to reload way after hours.
Thanks Jon
John
03-23-2009 02:55 PM
Are you sure about the release number?
__
Edison.
03-23-2009 02:58 PM
No...of course not =)
It's 12.4(24)T. That's a definite.
c2800nm-ipbasek9-mz.124-24.T.bin
03-23-2009 03:02 PM
It's documented on the release notes:
http://www.cisco.com/en/US/docs/ios/12_4t/release/notes/124TNEWF.html#wp1822285
HTH,
__
Edison.
03-23-2009 03:01 PM
I don't even see 12.2(24) is IOS selector.
Strange!
