BGP issue*
Hi Guys
There is problem with bgp multihomed configuration where i need redundancy between two diffrent ISP terminated on
same router .fa interface for the ISP2 is getting chocked and i gues its due to reverse path .
Please help here to configure redundancy and load sharing with BGP in case of two ISP on single router .
below is my configuration -
interface GigabitEthernet0/0
description  =======================ISP1
ip address x.x.x.13 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
duplex auto
speed auto
interface FastEthernet0/0/0
description ---------------------ISP 2
ip address x.x.x.2 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
duplex full
speed 100
router bgp 56061
no synchronization
bgp log-neighbor-changes
network x8x.xx8.x2.0 mask 255.255.255.0
neighbor x.x.x.41 remote-as 4xx5====================>>ISP2
neighbor x.x.x.41 route-map AS_PREPEND out
neighbor x.x.x.14 remote-as 18xx1 ======================ISP1
neighbor x.x.x.14 weight 500
neighbor x.x.x.14 route-map ADVT out
no auto-summary
route-map AS_PREPEND permit 10
match ip address prefix-list ADV
set as-path prepend 56061 56x61 56x61 56x61
GigabitEthernet0/0 is up, line protocol is up
  Hardware is PQ3_TSEC, address is 68ef.bdb7.b0b0 (bia 68ef.bdb7.b0b0) --------connected to ---------ISP1
  Description: "EON Internet WAN"
  Internet address is x.x.x.x/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
    reliability 255/255, txload 4/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/492/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 557000 bits/sec, 90 packets/sec
  5 minute output rate 1587000 bits/sec, 914 packets/sec
    4118392465 packets input, 4094842836806 bytes, 0 no buffer
    Received 7796 broadcasts, 0 runts, 0 giants, 25 throttles
    1 input errors, 0 CRC, 0 frame, 1 overrun, 0 ignored
    0 watchdog, 0 multicast, 0 pause input
    4492175709 packets output, 917883638205 bytes, 0 underruns
    0 unknown protocol drops
    0 lost carrier, 0 no carrier, 0 pause output
FastEthernet0/0/0 is up, line protocol is up
  Hardware is FastEthernet, address is 68ef.bd00.0bff (bia 68ef.bd00.0bff) --------connected to ---------ISP2
  Description: APNIC- LINK Tata 6 MB (020100224846) ***
  Internet address is x.x3.x.x/30
    reliability 255/255, txload 1/255, rxload 15/255
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:23, output 00:00:08, output hang never
  Last clearing of "show interface" counters 7w6d
  5 minute input rate 6120000 bits/sec, 835 packets/sec
    1339856029 packets input, 1160684921670 bytes
    Received 353 broadcasts, 0 runts, 0 giants, 0 throttles
    0 watchdog
    667749 packets output, 41399459 bytes, 0 underruns
    0 output errors, 0 collisions, 4 interface resets
cadet alain
hi,
you mean all traffic is coming in on the ISP2 link only or what else?
Regards.
Alain
hi Alain,
yes , and its gettng chocked and packet drops while I have available b/w on IPS1  .I want this to work like reverse traffic also should come via ISP1 where I have enouh b/w .
Thanks for reply
