Community Member
BGP Issue..
BGP synchronization is used to ensure that _____.
A. all the routers running BGP within an autonomous system start at the same time
B. BGP routers must have clocks synchronized
C. information throughout an autonomous system is consistent
D. information shared between Autonomous Systems is consistent
Mahi
Purple
Re: BGP Issue..
The answer is C. This prevents the black-holing of traffic.
Hope that helps - pls do remember to rate posts that help.
Paresh
Community Member
Re: BGP Issue..
Bronze
Re: BGP Issue..
C. is correct. If all the routers in the AS are running BGP, then synchronization is not needed.
91
