Community Member
BGP Loopback with MLPPP?
We are a multihomed site currently using a fractional DS3 with BGP routing. We are getting ready to move to individual T1's using MLPPP and BGP routing. Should we configure a loopback interface or use the multilink interface as a BGP peer?
1 REPLY
Purple
Re: BGP Loopback with MLPPP?
There is perfectly no problem with using the multilink interface for EBGP peering (I presume you are talking about EBGP here). If you are using IBGP, I would recommend peering to loopbacks...
So go ahead and do so...
Hope that helps - pls rate the post if it does.
Paresh.
133
