11-20-2005 01:26 PM - edited 03-03-2019 11:01 AM
I've got problems to set up md5 peer authentication with internal bgp. Is just md5 peer authentication supported on external peers?
any input is welcome
Oli
11-20-2005 02:36 PM
Hello Oli,
BGP MD5 authentication works on any TCP session, regardless of iBGP or eBGP. What exactly is the problem ?
This might not apply to you at all, but if you are using a PIX, you might want to check this document:
Sample Configurations of BGP Across a PIX Firewall
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009487d.shtml
GP
