BGP Migration to another Provider
I have been tasked with changing our primary BGP path to another provider.
We have an two edge routers at different NAPs and both are peered with many other ISPs through the NAPs network. However, we use two primary tier 1 ISPs for our primary and secondary paths.
At one NAP we are connecting up with a new provider, and retaining the old one until the contract expires.
I am looking for some tips on the migration process. The idea is to use the new provider as our primary path. with all other peers for shortest paths to respective AS's.
How much downtime, and flapping will be caused by doing this. Anyone who has done this before, what are the gotchas.
Thanks a mil
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
1 REPLY
Hall of Fame Super Silver
Re: BGP Migration to another Provider
Hello Stephen,
you can follow some steps:
a) setup the eBGP session to the new provider
advertise your IP prefixes to this neighbor
Use a public looking glass to verify the correct propagation of your advertisements or have the new provider's feedback
b) verify you are receiving a BGP full table from the new provider just use sh ip bgp summary and compare the number of prefixes receveid by the old and by the new provider
they don't need to match but to be of the same order
note: to do this you need to verify that you have at least 100 MB of free memory on your router to hold all the prefixes you receive in the new eBGP session
c) after all checks you can provide preference to the new provider for outgoing traffic
note: until you have the eBGP session with the old provider you have limited influence on the return path you can just prepend your own AS number in your advertisements to old provider
Hope to help
Giuseppe
131
