BGP Multihome - different ISPs - not honoring prepends
I'm setting up a multi-home scenario:
1) One site
2) /24 IP prefix
3) Registered, public AS
4) Two links (two different ISPs) - ISP A and ISP B
5) iBGP between them
6) ISP A should be primary for all inbound and outbound traffic
7) ISP B should be backup for all inbound and outbound traffic - ie, no traffic on this link in normal operation
I've done this with the use of local-pref inbound (and we're only receiving the default from both ISPs) and as path prepends outbound on the ISP B router.
All seems to be functioning more or less as expected, except that lookups on certain public route servers out on the net show the ISP B path as being preferred.
I assume this may be due to some form of route filtering or manipulation on the part of the given provider who's route server I'm looking at (such as filtering ISP A to only use routes they originate), but I'm wondering if there's anything I can do about this.
We really want to have the backup circuit completely un-used in normal operations (for a variety of reasons), but that is currently not the case.
Here's some config snippets, obviously altered to protect the innocent:
ISP A router (Primary):
ip prefix-list default description Matches default route
ip prefix-list default permit 0.0.0.0/0
ip prefix-list main-subnet description Matches x.x.x.x/24 subnet
ip prefix-list main-subnet permit x.x.x.x/24
route-map ispa-in permit 10
match ip address prefix-list default
set local-preference 200
route-map ispa-out permit 10
match ip address prefix-list main-subnet
router bgp 12345
no synchronization
bgp log-neighbor-changes
timers bgp 15 45
network x.x.x.x mask 255.255.255.0
neighbor 1.2.3.4 remote-as <ISP-A--AS>
neighbor 1.2.3.4 soft in
neighbor 1.2.3.4 route-map ispa-out out
neighbor 1.2.3.4 route-map ispa-in in
neighbor other.local.router remote-as 12345
neighbor other.local.router next-hop-self neighbor other.local.router soft in
ISP B router (backup):
route-map ispb-in permit 10
set local-preference 150
route-map ispb-out permit 10
set as-path prepend 12345 12345 12345 12345 12345
router bgp 12345
no synchronization
timers bgp 15 45
neighbor 5.6.7.8 remote-as <ISP-B--AS>
neighbor 5.6.7.8 soft in
neighbor 5.6.7.8 route-map ipsb-out out
neighbor 5.6.7.8 route-map ispb-in in
router bgp 12345
no synchronization
timers bgp 15 45
10 Replies 10
Marwan ALshawi
The logic of the config from your end looks ok
Try to contact ISPB and ask for a bgp community the you add it to the route advertised over ISP B so that they give it less preference within their cloud
Hope this help
darren.g
Level 5
Level 5
1) One site
2) /24 IP prefix
Duncan.
I ran into exactly the same scenario at my last job (and something very similar at this one), and unfortunately I couldn't find out how to do anything about - especially if the upstream ISP's are big enough.
Sometimes, no matter how much you prepend, the AS path is just going to be shorter from ISP B than it is from ISP A for inbound traffic, resultiting in traffic being routed in via ISP B - especially for other clients who directly connect to ISP B, and are either in their AS (single homed to ISP B), or who are a direct downstream from ISP B and several hops from ISP A's interconnect with ISP B.
I route all outbound traffic via my ISP A, but inbound I can't seem to do Jack about.
About the only thing you could try is to contact ISP B and see if they can damp the precedence within their AS - but they're not likely to be co-operative with that, since it introduced inefficiences within their AS.
Cheers.
ISPs they use BGP community string for policy routing
each ISP has some community stings that make any route within its cloud preferred to its customers even if you prepend because they increase the local preference within their cloud
for example if you want to access prefix x.x.x.x from a client whos ISPB customer the path over ISPB will prefered rather than the path over Inter ISP link between ISPB and ISPA
thats why if you ask ISPB what the bgp community string you need to ad to the route in addition to the AS prepend to make it less preferred this mostly will fix it
Hope this Help
you dont need BGP community in this case as you already are using the as path prepend on your back up router. So your config should work just fine. You use communities when you want your ISP to manipulate the BGP attributes at their end. In this case you are dong everything so it should be fine
Please rate if helpful
Kishore
the original poster has mentioned that although everything is configured correct the path selection is not working as desired and i suggested him to confirm with ISP B regarding the BGP community string to make sure they do not give preference to the advertised prefixes within their cloud over the inter ISP link
hope this help
marwan,
sorry i sent my msg using the cisco iphone app. It didnt display the whole original post so I didnt see the whole description.
Kishore
Hi Darren,
I agree: As long as you are advertising your prefixes to both ISPs, you can't be 100% sure the secondary ISP connection will not be used for incoming traffic.
So one idea:
Why not to try some kind of BGP conditional advertisement?
See  http://www.cisco.com/en/US/customer/tech/tk365/technologies_configuration_example09186a0080094309.shtml
It might be possible to advertise my prefixes to the secondary ISP only in case the BGP session to the primary ISP fails?
HTH,
Milan
Marwan ALshawi
Well this conditional advertisement should work but it is better to have the range advertised over both as it's using public range and public AS number over the Internet ( quicker re routing over the Internet )
There are some good points above, thank you.
I think I'm going to end up taking a blend of all of the suggestions.
I'm going to start by contacting ISP B and seeing about a community or dampening that will make it the less-preferred route in their cloud.
Failing that, I'll just toss on a bunch of prepends and it will have to be good enough.
The conditional advertisement was something I had contemplated as a solution, but it felt kind of like using a sledgehammer where a ballpeen hammer would do.
Where I think I will use the conditional advertisement is when we stand up the DR site. It has a separate AS and I planned on having it be the third advertisement point for the subnet, but there won't be any IBGP between DR and the Main site, so I definitely can't have active traffic coming there. A conditional advertisement would probably be the right call there, though I'll need to figure out how to craft it.
I would assume I can't use the main /24 as the non-exist condition, since even if the main site went dark, as soon as the DR site started advertising the main /24, it would again see that /24, match the non-exist and pull the advertisement.
Maybe I can do an eBGP multihop between the sites and pass a private /32 loopback or something...
Need to think on that.
Thanks again!
You are in the right track now
Confirm with ISPB if they can provide you with bgp comma ity string to make this route with less prefered in conjunction with AS prepending you did
Good luck
Plz rate the helpful posts
