Hello Rajesh,
Using IBGP between these 2 routers is not a necessity. It depends on your scenario.
And the same is valid for synchronization. Its not needed in many scenarios. And, when disabled there's no other configuration required.
Again, this depends on other factors, like: are you redistributing BGP? are these 2 internal routers directly connected? are you a transit AS?
this reply is far from complete, but I hope it's a start.
Please rate this post if it was helpful.
Vlad
