BGP multiple routes
ashish
I have a topology as per attached diagram. R1,R2 and R3 are running OSPF and R1 and R3 are having iGBP neighborship. I have redistributed OSPF in BGP and BGP in OSPF so that AS 100 becomes an transit AS. Now i have networks 7.7.7.1/24,8.8.8.1/24,9.9.9.1/24 and 10.10.10.1/24 on R2 which i advertised in OSPF. I can see 2 bgp routes for all these networks on R6 and R5 but on R4 i can only see single route for these networks which is through R3.
When i clear bgp routes with command clear ip bgp * on R4 2 routes on R5 becomes single route i.e. through R3 and on R4 single route becomes 2 routes i.e. one from R3 nad other from R6.
According to my understanding on R6, R4 nad R5 i should see 2 routes for these networks while on either R4 or R5 i see only single route for these networks.
I have pasted the configs of all routers as below:
R1 CONFIG
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname R1
ip subnet-zero
call rsvp-sync
interface Loopback0
ip address 1.1.1.1 255.255.255.0
interface Serial0/0
ip address 150.1.14.1 255.255.255.0
serial restart-delay 0
clockrate 64000
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
interface FastEthernet1/0
ip address 150.1.12.1 255.255.255.0
duplex auto
speed auto
router ospf 100
log-adjacency-changes
redistribute bgp 100 subnets
network 1.1.1.0 0.0.0.255 area 0
network 150.1.12.0 0.0.0.255 area 0
router bgp 100
no synchronization
bgp router-id 1.1.1.1
bgp log-neighbor-changes
network 1.1.1.0 mask 255.255.255.0
network 150.1.12.0 mask 255.255.255.0
network 150.1.14.0 mask 255.255.255.0
redistribute ospf 100
neighbor 3.3.3.3 remote-as 100
neighbor 3.3.3.3 update-source Loopback0
neighbor 3.3.3.3 next-hop-self
neighbor 4.4.4.4 remote-as 400
neighbor 4.4.4.4 ebgp-multihop 2
neighbor 4.4.4.4 update-source Loopback0
no auto-summary
ip classless
ip route 4.4.4.4 255.255.255.255 150.1.14.4
ip http server
ip pim bidir-enable
dial-peer cor custom
gatekeeper
shutdown
R2 CONFIG
hostname R2
ip subnet-zero
interface Loopback0
ip address 2.2.2.2 255.255.255.0
interface Loopback1
ip address 7.7.7.1 255.255.255.0
interface Loopback2
ip address 8.8.8.1 255.255.255.0
interface Loopback3
ip address 9.9.9.1 255.255.255.0
interface Loopback4
ip address 10.10.10.1 255.255.255.0
ip address 150.1.12.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet2/0
ip address 150.1.23.2 255.255.255.0
duplex auto
speed auto
router ospf 100
network 2.2.2.0 0.0.0.255 area 0
network 7.7.7.0 0.0.0.255 area 0
network 8.8.8.0 0.0.0.255 area 0
network 9.9.9.0 0.0.0.255 area 0
network 10.10.10.0 0.0.0.255 area 0
network 150.1.23.0 0.0.0.255 area 0
Thanks in advance
Best Regards
ashish
Please find below the configs of remaining routers
R3 CONFIG
hostname R3
ip subnet-zero
interface Loopback0
ip address 3.3.3.3 255.255.255.0
interface Serial0/0
ip address 150.1.35.3 255.255.255.0
no fair-queue
clockrate 64000
interface Serial0/1
no ip address
shutdown
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
ip address 150.1.23.3 255.255.255.0
duplex auto
speed auto
router ospf 100
network 3.3.3.0 0.0.0.255 area 0
router bgp 100
no synchronization
bgp router-id 3.3.3.3
network 3.3.3.0 mask 255.255.255.0
network 150.1.23.0 mask 255.255.255.0
network 150.1.35.0 mask 255.255.255.0
neighbor 1.1.1.1 remote-as 100
neighbor 1.1.1.1 update-source Loopback0
neighbor 1.1.1.1 next-hop-self
neighbor 5.5.5.5 remote-as 500
neighbor 5.5.5.5 ebgp-multihop 2
neighbor 5.5.5.5 update-source Loopback0
no auto-summary
ip classless
ip route 5.5.5.5 255.255.255.255 150.1.35.5
ip http server
ip pim bidir-enable
R4 CONFIG
hostname R4
ip subnet-zero
interface Loopback0
ip address 4.4.4.4 255.255.255.0
interface Loopback1
ip address 144.1.1.1 255.255.255.0
interface Serial0/0
ip address 150.1.14.4 255.255.255.0
no fair-queue
interface Serial0/1
ip address 180.180.180.2 255.255.255.0
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
router bgp 400
bgp router-id 4.4.4.4
bgp cluster-id 2415984897
network 4.4.4.0 mask 255.255.255.0
network 144.1.1.0 mask 255.255.255.0
network 150.1.1.0 mask 255.255.255.0
network 180.180.180.0 mask 255.255.255.0
neighbor 1.1.1.1 ebgp-multihop 2
neighbor 6.6.6.6 remote-as 600
neighbor 6.6.6.6 ebgp-multihop 2
neighbor 6.6.6.6 update-source Loopback0
ip classless
ip route 1.1.1.1 255.255.255.255 150.1.14.1
ip route 6.6.6.6 255.255.255.255 180.180.180.1
R5 CONFIG
hostname R5
ip subnet-zero
interface Loopback0
ip address 5.5.5.5 255.255.255.0
interface Loopback1
ip address 15.1.1.1 255.255.255.0
interface Serial0/0
ip address 150.1.35.5 255.255.255.0
no fair-queue
interface Serial0/1
ip address 190.190.190.2 255.255.255.0
interface Serial0/2
no ip address
shutdown
interface Serial0/3
no ip address
shutdown
router bgp 500
no synchronization
bgp router-id 5.5.5.5
bgp cluster-id 251724033
network 5.5.5.0 mask 255.255.255.0
network 190.190.190.0 mask 255.255.255.0
neighbor 3.3.3.3 ebgp-multihop 2
no auto-summary
ip classless
ip route 3.3.3.3 255.255.255.255 150.1.35.3
ip route 6.6.6.6 255.255.255.255 190.190.190.1
Can you post a sh ip bgp and sh ip route from all the routers?
Narayan
Dear Narayan
Please find attached the sh ip route and sh ip bgp of all the routers, Routers R1,R2 and R3 are running OSPF .
Ashish
I do not claim to have understood every detail of your setup. However, having made a quick look throughout your config, your bgp tables and your routing tables, I do have a few first comments to make.
1) When you examine the routes you have in the bgp table or in the routing table, do not forget to pay attention to the mask that accompanies the route. Some of the /24 routes you claim you can see in your first posting are /32's instead.
2) Redistribution is a tricky thing. Mutual redistribution takes this to another level. Unfortunately, many people are unlucky enough to have to study it :-). You have a non-deterministic setup, that is your cannot easily tell what the routing behavior is when a slight change happens in the network (clear the bgp). Redistribution is better when it is highly controlled in specific parts of the network.
3) In routers that run both BGP and OSPF make sure you have /32 loopback's (instead of /24's) as router-id's and that on a single router the bgp router-id and the ospf-router-id are the same. In general, ospf normally likes /32 router-id's and bgp and ospf interwork better when they have the same router-id.
4) Redistribution of iBGP routes into IGP (that is ospf in your case) is disabled by default to avoid routing loops within an AS and you have to explicitly issue (inside the bgp process configuration) the command bgp redistribute-internal. Even with this extra command, you would better setup some route-maps to have better control over your redistribution.
Kind Regards,
M.
