BGP not advertising a particular subnet
Please refer to the following configuration. I want to know why the subnet 12.23.0.0/18 is not advertised out.
router bgp aaaaa
no synchronization
no bgp log-neighbor-changes
network 12.23.0.0 mask 255.255.192.0
network 12.35.0.0 mask 255.255.192.0
network 12.35.64.0 mask 255.255.224.0
network 12.35.86.0 mask 255.255.255.0
network 20.10.218.180 mask 255.255.255.255
neighbor 22.23.62.23 remote-as 4773
neighbor 22.23.62.23 route-map AS-PREPEND out
no auto-summary
route-map AS-PREPEND permit 10
match ip address prefix-list prependlist
set as-path prepend aaaaa
route-map AS-PREPEND permit 20
ip prefix-list prependlist seq 5 permit 12.23.0.0/18
Router> sh ip bgp ne 22.23.62.23 ad
BGP table version is 8389, local router ID is 20.10.218.180
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
*> 12.35.0.0/18 12.35.35.2 30720 32768 i
*> 12.35.64.0/19 12.35.35.2 30720 32768 i
*> 12.35.86.0/24 12.35.35.2 30720 32768 i
*> 20.10.218.180/32
0.0.0.0 0 32768 i
Router>sh ip bgp 12.23.0.0
BGP routing table entry for 12.23.0.0/18, version 7068
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Not advertised to any peer
4773 65204, (aggregated by 65204 22.23.6.46)
22.32.62.23 from 22.32.62.23 (22.23.62.23)
Origin IGP, localpref 100, valid, external, atomic-aggregate, best
Extended Community: RT:4773:4801
Re: BGP not advertising a particular subnet
Try routing 12.23.0.0/18 to a null interface. Be sure you have more specific routes in your IGP.
interface null0
ip route 12.23.0.0 255.255.192.0 null0
Don't forget to soft reset the BGP advertisement.
clear ip bgp 22.23.62.23 soft out
Hello!
I would advice first do a
sh ip route | i 12.23.0.0
if there you cannot find anything related to this subnet, then follow the steps from medan post.
@medan, very good explanation, you have your post rated by me.
Best regards,
Calin
Thanks Calin, your advice is good also in case there is already a route locally.
419
