12-21-2006 05:02 AM - edited 03-03-2019 03:08 PM
Does 2620 support BGP..
Solved! Go to Solution.
12-21-2006 05:26 AM
Yes, it does. For more information on what feature set is required to support BGP, please refer to the Cisco Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Hope this helps,
12-21-2006 05:26 AM
Hope this helps,
12-21-2006 08:19 PM
Hi Hritter,
Thanks for your help.
I have two routers onr is 3700 series and one is 2620XM and i have two internet links from different ISPs along with this i have BGP pool/permission to use and two 515E PIX.
I require VPN tunnel redundancy to one of my remote office (using Cisco VPN concentrator) as well as load sharing over thease two links so that if one link/hardware goes down the traffic shift to other...Full mesh network..using all above..can you suugest solution for this..THanks in advance
rds,
gm
