Community Member
BGP on a 3640 %SYS-2-MALLOCFAIL:
Hi I have a big problem with one of the my edge internet routers (they are in high availability) both are Cisco 3640 R1&R2 today I have a problem with one of them R1, the bgp session was down an all traffic was redirected to the other one R2.
When the session came Up in R1 the router R2 started to drop the bgp sessions and I received a couple of messages like this
*Feb 28 18:04:15: %SYS-2-MALLOCFAIL: Memory allocation of 65536 bytes failed from 0x603F835C, align
ment 0 Pool: Processor Free: 17236 Cause: Not enough free memory Alternate Pool: None Free: 0 Cause: No Alternate pool
-Process= "BGP Router", ipl= 0, pid= 83
-Traceback= 603FC800 603FEE5C 603F8364 606C5160 6069BEEC 606ADCA0 606AE180 606A114C 606A636C
I reset the router several times without success according Cisco Site web is a memory problem but I do not understand what started the problem.
Re: BGP on a 3640 %SYS-2-MALLOCFAIL:
hi,
this could just be a faulty memory chip, or simply normal growth of the BGP table. Assuming both 3640 are the same with respect to hardware I would assume a memory chip problem. What does "sh proc mem" and "show version" on both routers give you?
You might need a memory replacement.
Hope this helps! Please rate all posts.
Regards, Martin
Community Member
This is the output for sh proc mem
#sh processes memory
Total: 97959008, Used: 4369728, Free: 93589280
PID TTY Allocated Freed Holding 9 0 0 0 12828 0 0 OIR Handler
0 6828 0 0 Per-minute Jobs
28 0 20108 188 26796 0 0 Call Management
29 0 0 0 6828 0 0 CES Line Conditi
30 0 42260 712 42176 0 0 Framer backgroun
31 0 188 188 6828 0 0 AAA Dictionary R
32 0 3708 0 15356 0 0 IP Input
44 0 0 1180 12828 0 0 TCP Timer
45 0 74060 0 12828 0 0 TCP Protocols
46 0 0 0 6828 0 0 Probe Input
47 0 0 0 6828 0 0 RARP Input
48 0 0 0 6828 0 0 HTTP Timer
49 0 0 0 6828 0 0 Socket Timers
50 0 29316 188 22300 0 0 DHCPD Receive
51 0 0 0 6828 0 0 IP Cache Ager
52 0 1068 0 25896 0 0 COPS
PID TTY Allocated Freed Holding Getbufs Retbufs Process
53 0 0 0 6852 0 0 PAD InCall
54 0 188 188 12828 0 0 X.25 Background
55 0 0 0 6828 0 0 SNMP Timers
56 0 0 0 9828 0 0 CES Client SVC R
57 0 152 0 6980 0 0 CEF Scanner
58 0 34364 188 41004 0 0 CCVPM_HDSPRM
59 0 188 188 6828 0 0 Net Serv Timer
60 0 20952 0 45780 0 0 TSP
61 0 65800 0 90628 0 0 QOS_MODULE_MAIN
62 0 12332 0 22160 0 0 CCVPM_HTSP
63 0 428 0 7256 0 0 CCVPM_R2
64 0 328 0 7156 0 0 CCSWVOICE
65 0 188 188 6828 0 0 Background Loade
66 0 340 0 7168 0 0 sssapp
67 0 0 0 6828 0 0 Syslog Traps
68 0 0 0 6828 0 0 trunk conditioni
69 0 1196 0 8024 0 0 trunk conditioni
70 0 188 188 12828 0 0 Standby (HSRP)
71 0 23076 23076 6828
4369448 Total
AND THE VERSION IS
ROM: 3600 Software (C3640-IS-M), Version 12.2(29),
uptime is 24 minutes
System image file is "flash:c3640-is-mz.122-29.bin"
cisco 3640 (R4700) processor (revision 0x00) with 125952K/5120K bytes of memory.
Processor board ID 24395868
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Primary Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
2 Channelized E1/PRI port(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Let me tell you I made a upgrade IOS few minutes ago thinking in a IOS problem
265
