bgp path selection issue
hi,
i have the following cli show command output,
R2#show bgp ipv4 unicast
BGP table version is 11, local router ID is 192.168.220.252
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
* i192.168.30.0     192.168.110.70           0    100      0 63000 i
*>                  192.168.220.70           0             0 63000 63000 i
* i192.168.40.0     192.168.110.70           0    100      0 63000 63000 i
*>                  192.168.220.70           0             0 63000 i
R2#
why isn't the route through the shortest AS path not selected as the best route for 192.168.30.0. ?
thanks,
uddika
2 Accepted Solutions
It seems that one is ibgp learnt route. Please show the output form the command show ip bgp 192.168.30.0.
Hello Uddika,
yes use of next-hop-self is a good practice.
However, there are two other options:
a) to have each border router to advertise its own border link(s) subnet(s) in iBGP with a network command under BGP process
b) to use an IGP like OSPF with the passive-interface option to make border links connecting to other ASes known to other iBGP speakers as IP subnets.
Hope to help
Giuseppe
10 Replies 10
R2#
R2#
R2#show ip bgp 192.168.30.0
BGP routing table entry for 192.168.30.0/24, version 7
Paths: (2 available, best #2, table Default-IP-Routing-Table)
  Advertised to update-groups:
    192.168.110.70 (inaccessible) from 192.168.111.251 (192.168.111.251)
      Origin IGP, metric 0, localpref 100, valid, internal
  63000 63000, (received & used)
    192.168.220.70 from 192.168.220.70 (192.168.220.70)
      Origin IGP, metric 0, localpref 100, valid, external, best
R2#
R2#
thanks, i noticed that R2 does not have the route for the next hop, 192.168.110.70.
i guess the recommended configuration is to advertise routes to ibgp peers with next-hope-self, isn't it?
Hello Uddika,
Hope to help
Giuseppe
        Already the route is learned via shortest as path only i think since the route is correctly learned from EBGP nly not IBGP..So why the additional config is required here? pls clarify
milan.kulik
Level 10
Level 10
isn't there
'bgp bestpath as-path ignore'
configured on the router?
Best regards,
Milan
no,.. i checked that.
in that case, can you paste more details?
sh ip bgp 192.168.30.0
output from both R2 and R1 plus BGP config section from both of them?
Best regards,
Milan
Hello Try a soft reset and check again Clear ip bgp * soft Res Paul
Kind Regards
Paul
didn't work, even rebooted all router.
