09-18-2006 09:58 AM - edited 03-03-2019 02:02 PM
In the decision making of BGP Best Path Selection; one is <<Perfer the path with lowest IGP metric to the BGP next-hop>>. Say one router (A) learns two routes from IBGP neibor ( B & C), and A_B has rip between them and A_C has OSPF between them. How will the BGP speaking router (A) decide which metric is lower to the BGP next hop.
Regrds,
Gaurav
09-18-2006 10:31 AM
In your scenario, Router A would use the OSPF route to get to the BGP next hop as it has a lower admin distance than RIP. The OSPF route is the one that will exist in the routing table of Router A to get to the BGP next hop. Metric comparison will come into play only when both routes belong to the same IGP.
Sundar
09-18-2006 05:40 PM
Thx Sundar,
So the neighbor whose next hop is learnt via OSPF will be preferref over that of rip ..thats due to Admin Distance..Right ?
G
09-18-2006 06:10 PM
Your understanding is correct!!
09-18-2006 07:50 PM
Thx, just an extension to question ...
Say if A learns the next hop for B & C from different routing protocols RIP & OSPF..then will this step be skipped..
Thx again,
G
09-19-2006 11:03 AM
yes ... IGP AD matters
09-21-2006 10:08 PM
Here is a note from RFC 4271 for breaking ties..
Can u explain in relation to my case of next hops learnt via RIP & OSPF
G
