BGP Peer group
we are configuring BGP Peer group manually? and the router with bgp neighbor peergroupname neighborRID will be the lead for the peer group right! somewhere i read that peer group lead is the lowest IP address router? so in that case how BGP peer group router member and lead will be elected?
Bronze
Re: BGP Peer group
I'm not sure if I understand your question, but BGP peer group RID's are not elected.
You configure BGP peer groups like this:
router bgp 100
neighbor external-peers peer-group
neighbor external-peers route-map set-metric out
neighbor external-peers filter-list 99 out
neighbor external-peers filter-list 101 in
neighbor 171.69.232.90 remote-as 200
neighbor 171.69.232.90 peer-group external-peers
neighbor 171.69.232.100 remote-as 300
neighbor 171.69.232.100 peer-group external-peers
neighbor 171.69.232.110 remote-as 400
neighbor 171.69.232.110 peer-group external-peers
neighbor 171.69.232.110 filter-list 400 in
http://www.cisco.com/en/US/docs/ios/12_0/np1/configuration/guide/1cbgp.html#wp5259
BR,
Bjornarsb
Re: BGP Peer group
well i was having the same understanding as per your configuration but in BGP design and Implementation book I read some thing like peer group lead... peer group lead is fine router with the command neighbor peer-group command is lead but there they are talking about the router with the lowest ip address will become a peer group lead and at that point I was confused... infect i am confuse right now too...
Re: BGP Peer group
As far as I am aware, the peer group does not have any effect outside this router. It is just a convenient way of configuring a set of neighbors all in the same way, and sending updates to them all at the same time. The neighbors themselves are not aware that they are part of a peer group.
Kevin Dorrell
Luxembourg
241
