BGP Peers and Neighbors, the differences
Can you please explain to me what are the differences between BGP peers and neighbors?
Thanks in advance,
with
Best Regards.
Re: BGP Peers and Neighbors, the differences
As far as i know, technically both the terms means the same in BGP.
You have some thing called Peer Groups in BGP configuration, which basically allows you to group BGP neighbors who share the same outbound policies together.
Check the following URL to know more on the same.
Hope this helps. Rate the post if you find it usefull
-VJ
Hi Vijayankar,
You forgot to give the URL :)
Thanks for your reply
Jayant
Hi Jayant,
Sorry about that.
Here it is.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080093fb7.shtml
-VJ
230
