Community Member
BGP Query
Hi All, I have a scenario given by customer and I am trying to figure out solution for that. See the scenario below
                                           Link A
Server Network---->Router<------------------->Router---------CustomerA
                              A    <---------------------->  B     ---------CustomerB
                                             LinkB
What custoemr wants that customer A should always use LinkA to reach Server and customer B should use link B to access server and there is EBGP peering between both the routers over both the link. Customer does not want to use Policy routing.
I am able to separate the link when server send traffic but in reply only one link is being used. Any suggesion will be very helpful. is there any way in BGP to achieve the above requirement. IBGP.Attributes, confederation anything ??
Ninja
VIP Super Bronze
Re: BGP Query
Hi Ninja,
If you want to separate customer-A from customer-B then you can put each customer in a their own VRF.
Reza
Hall of Fame Super Silver
Re: BGP Query
Hello Ninja,
I agree with Reza deploying VRF lite would allow you to deploy two logically separated topologies.
To be noted  that if one link fails the other cannot be used to carry traffic of the other VRF.
Also to be noted recent PBR implementation is efficient both in routers and in multilayer switches.
So PBR is probably the best solution because it allows to implement also link redundancy
Hope to help
Giuseppe
141
