Community Member
bgp redistribute-internal
Please correct me if I'm wrong. If i use the following commands, the following actions are supposed to happen:
1. The iBGP is allowed to be redistributed into OSPF
2. Because of the route-map, only the route to 131.189.0.0/16 will be redistributed into OSPF
3. I can use "clear ip bgp soft" command to make the redistribute-internal command effective without resetting the BGP session.
what may be the other potential negative results?
router bgp 111
router ospf 222
redistribute bgp 111 subnets route-map aaa
route-map aaa permit 10
match ip address prefix-list ToSomewhere
ip prefix-list ToSomewhere seq 10 permit 130.190.0.0/16
Re: bgp redistribute-internal
The impact may be high if you make any mistake in the route-map , it would bring down ur entire IGP as you might have many routes in all your routers learnt via Ibgp .
( Just think of entire internet routes getting installed into IGP ... IGP is not designed to handle this much )
Hope this helps.
regards
vanesh k
Community Member
According to my configuration, only the route to network 130.190.0.0/16 will be redistributed into OSPF, am I right?
Yes , but take care while doing any modification to route-map as you would see " dangerous " in the command itself.
regards
vanesh k
Community Member
Thanks a lot.
After I make the change, should I use "clear ip bgp *" to take it in effect? or I can use "clear ip bgp xx.xx.xx.xx soft" to affect only the neighbor from which I get the route?
The side-effect will be minimized by doing this.
I dont think you need a clear ip BGP as you are basically redistributing BGP traffic into OSPF.
After redistributing if you do not see the route in the OSPF database, you might try a clear ip ospf redistribution and check
Narayan
501
