BGP redistribution into OSPF
I am testing the idea of running BGP from 3rd partner extranet connections in an enterprise which will redistribute into an OSPF core. In my simplistic testing, I have an access router and a distribution router configured as a BGP confederation and the distribution router also shares an OSPF process and area 0 with the core router (a seperate BGP confederation). I have an external extranet partner in a seperate AS running an eBGP peering session with the access router which is injecting routes that appear all the way back in the core.
My problem is in how I implement redistribution into the IGP (OSPF) on the core router. Doing so creates a routing loop by re-advertising an OSPF E1 route (AD 110) for the extranet router source ranges back to the distribution router. As a result the distribution router thinks the best path is back through the core router as apposed to the iBGP learned route (AD 200). I'm a bit unsure as to the best method of addressing this. Any help would be appreciated. Thanks in advance.
Bronze
Re: BGP redistribution into OSPF
just fire in the default route mate if you can into your ospf process at the bgp external point.
Thanks for the help. Much appreciated. Always the simplest of solutions !
282
