BGP reload problem
Picture the following diagram, one Nexus switch with 2 BGP peers, one is eBGP the other one is iBGP. It receives the default router from both, the the one from eBGP si prefered. When the eBGP peer is reloaded, the following events occur on the Nexus switch:
-it removes the default route from the eBGP peer and adds it from the iBGP
-then adds back the default route from the eBGP peer since it is not fully down, and removes the one from the iBGP
This is happening for about 30-40 seconds until the eBGP peer is completly down, the default route from the iBGP peer is kept and everything is stable.
During this interval, there is packet loss.
Are there ways to prevent this behaviour ? I would like force the Nexus to keep the iBGP route all the wime while the eBGP peer is in the process of reloading.
This is happening only when the eBGP peer is reloaded, if I just reove the physical link between them, then the iBGP route is added and kept.
Thank you
Tudor
  • WAN Routing and Switching
1 ACCEPTED SOLUTION
BGP reload problem
just an idea:
When I see:
N7K-1# sh ip bgp 0.0.0.0
BGP routing table information for VRF default, address family IPv4 Unicast
BGP routing table entry for 0.0.0.0/0, version 121
Paths: (2 available, best #1)
Flags: (0x000002) on xmit-list, is not in urib
  Advertised path-id 1
  Path type: external, path is valid, received and used, is best path, is staled
  AS-Path: 65000 , path sourced external to AS
    10.0.11.1 (metric 0) from 10.0.11.1 (0.0.0.0)
      Origin IGP, MED not set, localpref 100, weight 0
is pointing me to BGP Graceful restart feature
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ftbgpnsf.html
The document says
"If the BGP session is lost during the RP switchover, the NSF-aware BGP peer marks all the routes associated with the NSF-capable router as stale; however, it continues to use these routes to make forwarding decisions for a set period of time."
There could be an IOS bug advertising RP switchover even while the router is rebooting?
Possibly you could try to disable graceful restart capability on your router?
Best regards,
Milan
Hall of Fame Super Blue
Re: BGP reload problem
Tudor
The only thing i can think of is route dampening where you can suppress a flapping route and this only applies to EBGP learned routes not IBGP. But that souds like it might fit.. I don't know whether it would work, or whether you have already considered/tried it but it might be worth a look -
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfbgp.html#wp1002395
Edit - i should say i have never had the need to use route dampening so i'm not saying for sure it is a solution but it sounds like it might fit your scenario.
Jon
BGP reload problem
Tudor
Are you sure that what you think is happening is actually happening ?
What are the BGP timers on the nexus switches with your EBGP neighbor. If the nexus realises the route is lost then that it sounds like the EBGP router has removed the route. So why would it advertise it again.
Where does the EBGP get the default route from. Is it originated on the EBGP router or is it passed on from another EBGP router ?
What is happening with the actual peering between the nexus and EBGP, is it up all the time ?
Jon
BGP reload problem
Hi Jon,
The timers are 30 and 90 , the default route is originated by the EGBP router, and the peering is up. Only when the status of the peering is in CLOSING then the Nexus keeps the route from the IBGP peer.
Plese see the output below: 10.0.1.11 being the EGBP peer and  10.1.12.2 being the IBGP peer:
2013 Dec  5 12:28:56.937949 bgp: 65001 [6673] RIB: [IPv4 Unicast] BGP received rnh notification from URIB for tid 0x1, nh 10.0.11.1/32
2013 Dec  5 12:28:56.937961 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Queuing RNH: 10.0.11.1/32 into critical updates list
2013 Dec  5 12:28:59.349153 bgp: 65001 [6673] (default) ADJ: 10.1.12.2 KEEPALIVE rcvd
2013 Dec  5 12:28:59.955585 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Processing RNH notification for 10.0.11.1/32
2013 Dec  5 12:28:59.955698 bgp: 65001 [6673] (default) RNH: Adjusting recursion for next-hop 10.0.11.1
2013 Dec  5 12:28:59.955714 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Resolving next_hop 10.0.11.1/32
2013 Dec  5 12:28:59.955754 bgp: fsrv_is_shared_intf_vdc(2215): srv_type: 2 vdc_id: 1
2013 Dec  5 12:28:59.955797 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, reachability changed, IGP cost changed, RNH epoch changed, reachable
2013 Dec  5 12:28:59.955816 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, updating 1 routes
2013 Dec  5 12:28:59.955831 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Triggering bestpath selection for 0.0.0.0/0 , flags=0x1000003a
2013 Dec  5 12:28:59.955887 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, scheduled 1 routes for bestpath
2013 Dec  5 12:28:59.955906 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, scheduled 1 routes for bestpath, triggers 54
2013 Dec  5 12:28:59.955942 bgp: 65001 [6673] (default) SUM: [IPv4 Unicast] Starting bestpath (xid 38)
2013 Dec  5 12:28:59.956072 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Allocating URIB buffer, xid 39
2013 Dec  5 12:28:59.956114 bgp: librpm 65001 [6673] invalid policy handle when checking policy readyness
2013 Dec  5 12:28:59.956130 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Begin select bestpath for 0.0.0.0/0, adv_all=0, cal_nth=0, install_to_rib=0, flags=0x10000038
2013 Dec  5 12:28:59.956157 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Sending route 0.0.0.0/0 to URIB
2013 Dec  5 12:28:59.956171 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast]: adding route 0.0.0.0/0 via 10.0.11.1
2013 Dec  5 12:28:59.956182 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Adding path to 0.0.0.0/0 via 10.0.11.1 in URIB (table-id 0x1)
2013 Dec  5 12:28:59.956197 bgp: fsrv_is_shared_intf_vdc(2215): srv_type: 2 vdc_id: 1
2013 Dec  5 12:28:59.956221 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Deleting path to 0.0.0.0/0 via 10.1.12.2:(null) in table 0x1 from URIB
2013 Dec  5 12:28:59.956235 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Updating path to 0.0.0.0/0 in URIB, nhs added 1, deleted 1
2013 Dec  5 12:28:59.956250 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Selected new bestpath 0.0.0.0/0 flags=0x10800018 rid=0.0.0.0 nh=10.0.11.1
2013 Dec  5 12:28:59.956265 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] 0.0.0.0/0 path#1: set to rid=0.0.0.0 nh=10.0.11.1, flags=0x6, changed=1
2013 Dec  5 12:28:59.956279 bgp: 65001 [6673] (default) BRIB: [IPv4 Unicast] 0.0.0.0/0, no Label AF
2013 Dec  5 12:28:59.956300 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Completed bestpath for 1 prefixes xid 39
2013 Dec  5 12:28:59.958537 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Queuing RNH: 10.0.11.1/32 into critical updates list
2013 Dec  5 12:29:01.905354 bgp: 65001 [6673] (default) ADJ: 10.12.12.2 keepalive timer fired
2013 Dec  5 12:29:01.905473 bgp: 65001 [6673] (default) ADJ: 10.12.12.2 keepalive timer fired for peer
2013 Dec  5 12:29:01.905567 bgp: 65001 [6673] (default) ADJ: 10.12.12.2 next keepalive expiry due in 00:00:21
2013 Dec  5 12:29:01.905586 bgp: 65001 [6673] (default) ADJ: 10.2.11.2 keepalive timer fired
2013 Dec  5 12:29:01.905607 bgp: 65001 [6673] (default) ADJ: 10.2.11.2 keepalive timer fired for peer
2013 Dec  5 12:29:01.905639 bgp: 65001 [6673] (default) ADJ: 10.2.11.2 next keepalive expiry due in 00:00:21
2013 Dec  5 12:29:01.905655 bgp: 65001 [6673] (default) ADJ: 10.1.12.2 keepalive timer fired
2013 Dec  5 12:29:01.905672 bgp: 65001 [6673] (default) ADJ: 10.1.12.2 keepalive timer fired for peer
2013 Dec  5 12:29:01.905702 bgp: 65001 [6673] (default) ADJ: 10.1.12.2 next keepalive expiry due in 00:00:21
2013 Dec  5 12:29:02.979194 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Processing RNH notification for 10.0.11.1/32
2013 Dec  5 12:29:02.979223 bgp: 65001 [6673] (default) RNH: Adjusting recursion for next-hop 10.0.11.1
2013 Dec  5 12:29:02.979239 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Resolving next_hop 10.0.11.1/32
2013 Dec  5 12:29:02.979277 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, reachability changed, IGP cost changed, RNH epoch changed
2013 Dec  5 12:29:02.979292 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, updating 1 routes
2013 Dec  5 12:29:02.979310 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Triggering bestpath selection for 0.0.0.0/0 , flags=0x10000022
2013 Dec  5 12:29:02.979365 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, scheduled 1 routes for bestpath
2013 Dec  5 12:29:02.979383 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, scheduled 1 routes for bestpath, triggers 55
2013 Dec  5 12:29:02.979419 bgp: 65001 [6673] (default) SUM: [IPv4 Unicast] Starting bestpath (xid 39)
2013 Dec  5 12:29:02.979569 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Allocating URIB buffer, xid 40
2013 Dec  5 12:29:02.979619 bgp: librpm 65001 [6673] invalid policy handle when checking policy readyness
2013 Dec  5 12:29:02.979637 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Begin select bestpath for 0.0.0.0/0, adv_all=0, cal_nth=0, install_to_rib=0, flags=0x10000020
2013 Dec  5 12:29:02.979663 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Sending route 0.0.0.0/0 to URIB
2013 Dec  5 12:29:02.979678 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast]: adding route 0.0.0.0/0 via 10.1.12.2
2013 Dec  5 12:29:02.979689 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Adding path to 0.0.0.0/0 via 10.1.12.2 in URIB (table-id 0x1)
2013 Dec  5 12:29:02.979706 bgp: fsrv_is_shared_intf_vdc(2215): srv_type: 2 vdc_id: 1
2013 Dec  5 12:29:02.979733 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Deleting path to 0.0.0.0/0 via 10.0.11.1:(null) in table 0x1 from URIB
2013 Dec  5 12:29:02.979748 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Updating path to 0.0.0.0/0 in URIB, nhs added 1, deleted 1
2013 Dec  5 12:29:02.981817 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Queuing RNH: 10.0.11.1/32 into critical updates list
2013 Dec  5 12:29:05.106716 bgp: 65001 [6673] (default) ADJ: 10.2.11.2 KEEPALIVE rcvd
2013 Dec  5 12:29:05.645361 bgp: 65001 [6673] (default) EVT: 10.0.11.1 peer connection retry timer expired
2013 Dec  5 12:29:05.645518 bgp: 65001 [6673] (default) EVT: Single hop EBGP peer 10.0.11.1 not directly attached (active), outbound interface Unknown
2013 Dec  5 12:29:05.995491 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Processing RNH notification for 10.0.11.1/32
2013 Dec  5 12:29:05.995618 bgp: 65001 [6673] (default) RNH: Adjusting recursion for next-hop 10.0.11.1
2013 Dec  5 12:29:05.995633 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Resolving next_hop 10.0.11.1/32
2013 Dec  5 12:29:05.995670 bgp: fsrv_is_shared_intf_vdc(2215): srv_type: 2 vdc_id: 1
2013 Dec  5 12:29:05.995709 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, reachability changed, IGP cost changed, RNH epoch changed, reachable
2013 Dec  5 12:29:05.995728 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, updating 1 routes
2013 Dec  5 12:29:05.995742 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Triggering bestpath selection for 0.0.0.0/0 , flags=0x1000003a
2013 Dec  5 12:29:05.995797 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, scheduled 1 routes for bestpath
2013 Dec  5 12:29:05.995817 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, scheduled 1 routes for bestpath, triggers 56
2013 Dec  5 12:29:05.995852 bgp: 65001 [6673] (default) SUM: [IPv4 Unicast] Starting bestpath (xid 40)
2013 Dec  5 12:29:05.995976 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Allocating URIB buffer, xid 41
2013 Dec  5 12:29:05.996016 bgp: librpm 65001 [6673] invalid policy handle when checking policy readyness
2013 Dec  5 12:29:05.996032 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Begin select bestpath for 0.0.0.0/0, adv_all=0, cal_nth=0, install_to_rib=0, flags=0x10000038
2013 Dec  5 12:29:05.996056 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Sending route 0.0.0.0/0 to URIB
2013 Dec  5 12:29:05.996071 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast]: adding route 0.0.0.0/0 via 10.0.11.1
2013 Dec  5 12:29:05.996084 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Adding path to 0.0.0.0/0 via 10.0.11.1 in URIB (table-id 0x1)
2013 Dec  5 12:29:05.996097 bgp: fsrv_is_shared_intf_vdc(2215): srv_type: 2 vdc_id: 1
2013 Dec  5 12:29:05.996121 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Deleting path to 0.0.0.0/0 via 10.1.12.2:(null) in table 0x1 from URIB
2013 Dec  5 12:29:05.996133 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Updating path to 0.0.0.0/0 in URIB, nhs added 1, deleted 1
2013 Dec  5 12:29:05.996148 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Selected new bestpath 0.0.0.0/0 flags=0x10800018 rid=0.0.0.0 nh=10.0.11.1
2013 Dec  5 12:29:05.996161 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] 0.0.0.0/0 path#1: set to rid=0.0.0.0 nh=10.0.11.1, flags=0x6, changed=1
2013 Dec  5 12:29:05.996175 bgp: 65001 [6673] (default) BRIB: [IPv4 Unicast] 0.0.0.0/0, no Label AF
2013 Dec  5 12:29:05.996195 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Completed bestpath for 1 prefixes xid 41
2013 Dec  5 12:29:05.998201 bgp: 65001 [6673] RIB: [IPv4 Unicast] BGP received rnh notification from URIB for tid 0x1, nh 10.0.11.1/32
2013 Dec  5 12:29:05.998221 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Queuing RNH: 10.0.11.1/32 into critical updates list
2013 Dec  5 12:29:07.606445 bgp: 65001 [6673] (default) ADJ: 10.12.12.2 KEEPALIVE rcvd
2013 Dec  5 12:29:09.015460 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Processing RNH notification for 10.0.11.1/32
2013 Dec  5 12:29:09.015608 bgp: 65001 [6673] (default) RNH: Adjusting recursion for next-hop 10.0.11.1
2013 Dec  5 12:29:09.015624 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] Resolving next_hop 10.0.11.1/32
2013 Dec  5 12:29:09.015658 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, reachability changed, IGP cost changed, RNH epoch changed
2013 Dec  5 12:29:09.015678 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, updating 1 routes
2013 Dec  5 12:29:09.015693 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Triggering bestpath selection for 0.0.0.0/0 , flags=0x10000022
2013 Dec  5 12:29:09.015748 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, scheduled 1 routes for bestpath
2013 Dec  5 12:29:09.015766 bgp: 65001 [6673] (default) RNH: [IPv4 Unicast] next-hop 10.0.11.1/32, scheduled 1 routes for bestpath, triggers 57
2013 Dec  5 12:29:09.015802 bgp: 65001 [6673] (default) SUM: [IPv4 Unicast] Starting bestpath (xid 41)
2013 Dec  5 12:29:09.015847 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Allocating URIB buffer, xid 42
2013 Dec  5 12:29:09.015884 bgp: librpm 65001 [6673] invalid policy handle when checking policy readyness
2013 Dec  5 12:29:09.016006 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Begin select bestpath for 0.0.0.0/0, adv_all=0, cal_nth=0, install_to_rib=0, flags=0x10000020
2013 Dec  5 12:29:09.016033 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Sending route 0.0.0.0/0 to URIB
2013 Dec  5 12:29:09.016045 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast]: adding route 0.0.0.0/0 via 10.1.12.2
2013 Dec  5 12:29:09.016056 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Adding path to 0.0.0.0/0 via 10.1.12.2 in URIB (table-id 0x1)
2013 Dec  5 12:29:09.016073 bgp: fsrv_is_shared_intf_vdc(2215): srv_type: 2 vdc_id: 1
2013 Dec  5 12:29:09.016101 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Deleting path to 0.0.0.0/0 via 10.0.11.1:(null) in table 0x1 from URIB
2013 Dec  5 12:29:09.016116 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Updating path to 0.0.0.0/0 in URIB, nhs added 1, deleted 1
2013 Dec  5 12:29:09.016128 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Selected new bestpath 0.0.0.0/0 flags=0x10800000 rid=10.0.22.2 nh=10.1.12.2
2013 Dec  5 12:29:09.016141 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] 0.0.0.0/0 path#1: set to rid=10.0.22.2 nh=10.1.12.2, flags=0x6, changed=1
2013 Dec  5 12:29:09.016155 bgp: 65001 [6673] (default) BRIB: [IPv4 Unicast] 0.0.0.0/0, no Label AF
2013 Dec  5 12:29:09.016176 bgp: 65001 [6673] (default) RIB: [IPv4 Unicast] Completed bestpath for 1 prefixes xid 42
BGP reload problem
is your eBGP neighbour using for peering an interface within a subnet directly connected to your Nexus?
As the debug mesages are talking about RNH = Recursive Next Hop I believe?
Best regards,
Milan
BGP reload problem
Hi Milan,
Yes the EBGP peer is directly connected, it is an ASR..
Some additional debug to confirm the events, how the N7K is choosing between paths, when path#2 is chosen, I have replies from downstream hosts, but when pach#1 is chosen back, I have downtime and it stays like this for 30-40 secs.
I have tried to lowe the bgp timers, to implement BFD, but no effect.. I ll try to use dampening although I wouldn't prefer it..
Tudor
N7K-1# ping 10.0.11.1
PING 10.0.11.1 (10.0.11.1): 56 data bytes
Request 0 timed out
Request 1 timed out
ping: sendto 10.0.11.1 64 chars, No route to host
Request 2 timed out
Request 3 timed out
Request 4 timed out
--- 10.0.11.1 ping statistics ---
5 packets transmitted, 0 packets received, 100.00% packet loss
N7K-1# ^C
BGP routing table entry for 0.0.0.0/0, version 118
Paths: (2 available, best #2)
Flags: (0x00001a) on xmit-list, is in urib, is best urib route
  Path type: external, path is invalid, received and used, is staled, no labeled nexthop
    10.0.11.1 (inaccessible, metric 4294967295) from 10.0.11.1 (0.0.0.0)
  Path type: internal, path is valid, received and used, is best path
    10.1.12.2 (metric 0) from 10.1.12.2 (10.0.22.2)
  Path-id 1 advertised to peers:
    10.2.11.2          10.12.12.2
BGP routing table entry for 0.0.0.0/0, version 120
  Path type: internal, path is valid, received and used, not best reason: Internal path
    10.1.12.2          10.2.11.2          10.12.12.2
BGP routing table entry for 0.0.0.0/0, version 122
BGP routing table entry for 0.0.0.0/0, version 123
BGP routing table entry for 0.0.0.0/0, version 124
BGP routing table entry for 0.0.0.0/0, version 125
BGP routing table entry for 0.0.0.0/0, version 127
BGP routing table entry for 0.0.0.0/0, version 128
N7K-1# sh ip bgp sum
BGP summary information for VRF default, address family IPv4 Unicast
BGP router identifier 10.0.11.2, local AS number 65001
BGP table version is 131, IPv4 Unicast config peers 4, capable peers 3
7 network entries and 14 paths using 1176 bytes of memory
BGP attribute entries [8/1088], BGP AS path entries [2/12]
BGP community entries [0/0], BGP clusterlist entries [0/0]
12 received paths for inbound soft reconfiguration
12 identical, 0 modified, 0 filtered received paths using 0 bytes
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
10.0.11.1       4 65000     736     751        0    0    0 00:01:47 Idle
10.1.12.2       4 65001     219     266      131    0    0 01:31:03 7
10.2.11.2       4 65002     185     261      131    0    0 01:30:05 1
10.12.12.2      4 65002     186     263      131    0    0 01:31:01 3
BGP routing table entry for 0.0.0.0/0, version 136
  Path type: external, path is invalid, received and used, is deleted, no labeled nexthop
BGP routing table entry for 0.0.0.0/0, version 137
Paths: (1 available, best #1)
BGP reload problem
just an idea:
When I see:
The document says
Best regards,
Milan
BGP reload problem
I have tried with/without graceful-restart feature with different restart/stal timers but no effect..
The annoying thing is that even if the bgp neighbour state is in IDLE, it still uses the route from it.Only when the state is CLOSING, the other route is prefered and kept...
Tudor
BGP reload problem
Hi Milan,
You were right, I was disabling the feature only on the EBGP peer, but right after I have disable it on the Nexus, it worked just fine. The only thing left to do, is to test how it works when I perform a switch over between supervisors.
Tudor
BGP reload problem
Just as an update, when the system switchover happens, with the graceful restart feature being disabled, there is not packet loss, although bgp goes down and comes up very fast.
634
