07-12-2007 06:13 AM - edited 03-03-2019 05:50 PM
i am having 7600 which is rinning with ospf as IGP and bgp peering with my ISP.I want to distribute the routes (10.255.255.252/32 and 10.255.255.10/32) thru route map to my neighbors.
my conf is
ip prefix-list TEST1 permit 10.255.255.252/32
ip prefix-list TEST1 permit 10.255.255.10/32
route-map TEST permit
match ip address prefix-list TEST1
router bgp 65006
neighbor 1.1.1.1 remote-as 65007
neighbor 1.1.1.1 route-map TEST out
my problem is i am not getting the both routes at the oher end.
regadrs
shivlu
Solved! Go to Solution.
07-12-2007 06:19 AM
Shivlu,
You first need to inject these prefixes in BGP via a network statement or redistribution from the IGP (or static). The network statement is usually the preferred approach. Note that the network statement has to match a route in the RIB for that route to be injected in BGP.
router bgp 65006
network 10.255.255.10 mask 255.255.255.255
network 10.255.255.252 mask 255.255.255.255
Hope this helps,
07-12-2007 06:19 AM
Shivlu,
router bgp 65006
Hope this helps,
