BGP Route Redistribution.
router-map name permit 10
match ip address 10
access-list 10 permit X.Y.Z
match ip address 10
access-list 10 deny X.Y.Z
router-map name deny 10
match ip address 10
Here route-map is deny but access-list is
permitted if i am redistributing protocols in this case
access-list 10 will be redistributed or not.
match ip address 10
In there any meaning to use this route-map with acl deny if yes
then where we can use .
Purple
Re: BGP Route Redistribution.
The 'access-list 10 deny X.Y.Z' will deny all addresses, not just X.Y.Z, simply because of the implicit deny at the end of the ACL.
That means that the first clause of the route-map will match all IP addresses, and deny all of them.
Now, if you had an ACL that had permit entries other than the deny, then what would happen is that it would match all addresses that are permitted. The route-map would then deny all of the addresses matched by the ACL and permit everything else. All of these other addresses would then fall through to the next clause of the route-map, if it exists.
Paresh
PS. Pls do remember to rate posts
match ip address 10
mean to say route-map permit match address
10 redistribute others except X.Y.Z
match ip address 10
Deny all the networks except X.Y.Z
Silver
Just like Paresh said. The first route-map will deny all ip address. Only if you add a "permit any" after the deny x.y.z ACL, then you will have your expected result.
IMO, the second route-map will deny x.y.z only and permit others.
You can try these route-map in your lab.
128
