BGP routing does not work on 7206vxr
bvictor
I need to move bgp router from 7609 to 7206.
7609 has IOS c6sup22-psv-mz.121-26.E4.bin
7206 has IOS c7200-ik9o3s-mz.123-17a.bin
config for 7609
interface Vlan15
ip address 2.0.5.0 255.255.255.252
interface Vlan195
ip address 5.9.0.1 255.255.255.192 secondary
ip address 2.6.5.1 255.255.255.0
no ip redirects
ip route-cache flow
ntp broadcast
interface Vlan708
ip address 5.2.5.4 255.255.255.252
router bgp 50
no synchronization
bgp router-id 5.9.0.1
bgp log-neighbor-changes
network 5.9.0.0
neighbor 2.0.5.9 remote-as 89
neighbor 2.0.5.9 weight 50
neighbor 2.0.5.9 route-map AddAS out
neighbor 2.0.5.9 filter-list 1 out
neighbor 4.4.8.7 remote-as 54
neighbor 4.4.8.7 ebgp-multihop 3
neighbor 4.4.8.7 weight 10
neighbor 4.4.8.7 route-map AddAS out
neighbor 4.4.8.7 filter-list 1 out
neighbor 5.2.5.3 remote-as 58
neighbor 5.2.5.3 weight 100
neighbor 5.2.5.3 filter-list 1 out
ip classless
ip route 4.4.8.7 255.255.255.255 2.6.5.5
ip as-path access-list 1 permit ^$
ip as-path access-list 1 deny .*
and config for 7206
interface GigabitEthernet0/1
no ip address
no ip mroute-cache
duplex auto
speed auto
media-type gbic
negotiation auto
ntp broadcast client
interface GigabitEthernet0/1.195
encapsulation dot1Q 195
ip address 2.6.5.1 255.255.255.0 secondary
no ip redirects
ntp broadcast
no snmp trap link-status
interface GigabitEthernet0/2
no ip mroute-cache
duplex auto
speed 100
media-type rj45
negotiation auto
interface GigabitEthernet0/3
no ip address
no ip mroute-cache
duplex full
speed 100
media-type rj45
no negotiation auto
interface GigabitEthernet0/3.708
encapsulation dot1Q 708
router bgp 50
no synchronization
network 5.9.0.0
no auto-summary
ip classless
What I configured wrong on 7206?
BGP is up on 7206 and I can ping any host outside my network from this router. But routing does not work on it. I can't to ping any host from my network to outside.
frosalia
You have flip-flopped primary and secondary IP addresses on g0/1.195 (old vlan 195). This may be part of you problem. Can you post 'sh ip bgp s'?
frosalia
It flip-flopped primary and secondary IP addresses on g0/1.195 and vlan 195 is a result of my experiments on config.
7609
Atlas#show ip bgp summ
BGP router identifier 195.149.110.1, local AS number 29450
BGP table version is 606478, main routing table version 606478
288388 network entries and 851404 paths using 58624180 bytes of memory
152643 BGP path attribute entries using 9161040 bytes of memory
137919 BGP AS-PATH entries using 4079840 bytes of memory
2394 BGP community entries using 159778 bytes of memory
8 BGP extended community entries using 240 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
100334 BGP filter-list cache entries using 1204008 bytes of memory
BGP activity 289064/1661 prefixes, 854568/3164 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
92.50.195.169 4 12389 63080 264 606478 0 0 02:09:42 283260
194.84.128.127 4 2854 51670 137 606478 0 0 02:12:04 281053
195.182.135.93 4 6858 57935 135 606478 0 0 02:10:46 287090
and for 7206
Styx#show ip bgp summ
BGP table version is 1575498, main routing table version 1575498
288439 network entries using 29132339 bytes of memory
851564 path entries using 40875072 bytes of memory
152670 BGP path attribute entries using 9160800 bytes of memory
137916 BGP AS-PATH entries using 4079556 bytes of memory
2391 BGP community entries using 159444 bytes of memory
120266 BGP filter-list cache entries using 1443192 bytes of memory
BGP using 84850643 total bytes of memory
BGP activity 577278/288839 prefixes, 1705370/853806 paths, scan interval 60 secs
92.50.195.169 4 12389 111146 102 1575498 0 0 00:01:34 283320
194.84.128.127 4 2854 97856 58 1575498 0 0 00:03:18 281105
195.182.135.93 4 6858 111204 56 1575498 0 0 00:02:19 287139
bvictor
It was my error.
In config 7206 bgp
no auto-summary was wrong line.
Now it works fine with
auto-summary
