01-22-2010 10:57 PM - edited 03-04-2019 07:16 AM
I have 3 sites. 2 sites were IPVPN connections provided by service provider through their MPLS cloud and the 3rd one was P2P DLL lease Line.
I recieved new lines from the same ISP for the sites and this time all 3 will be connected to the ISP and there will be no P2P lease line connection.
I recieved DSL connection for SITE 1. and ethernet connection for the other sites site 2 and site 3 and BGP configuration for neighbour.
I configured site 2 with the new neighbour and it works.
i also applied the same setting to the site 3 which was DLL p2p CONNECTION with Site 2 but the traffic is still going throuhg SITE2 instead of going direct through the Service provided MPLS cloud. since earlier there was no BGP on this router, there were static routes and also site 2 is advertising route to SITE 3 via site 2. I tried removing advertisement on site 2 for site 3 but then i lost connectivity.
When i trace from site 3 to site 1 I go through the ISP directly but when i trace from SITE 1 to site 3 It still goes via site 2.
Please some one help me resolve this issue.
01-23-2010 12:21 AM
ok now you have to have the following
in site 1 :
router bgp x
neighbor x.x.x.x remote-as yy - where x.x.x.x is the ISP bgp next hop
network y.y.y.y mask xy.xy.xy.xy -- the network supposed to be you site 1 LAN
site 2
router bgp x
network y.y.y.y mask xy.xy.xy.xy -- the network supposed to be you site 2 LAN
Site 3
router bgp x
network y.y.y.y mask xy.xy.xy.xy -- the network supposed to be you site 3 LAN
this is the standard and simple way, do you have your config like this
good luck
if helpful Rate
01-30-2010 10:36 PM
Thanks for the input. I have succefully formed BGP neighbours by doing the configuration like specified but am facing an issue not related. what can be the cause of this problem.
the performance over the wan links are not good. I am getting tremendous delay and drops on this link. I tried to connect directly to the telco modem and ping the neighbour network and didnt find any problem. there were no drops or request timeout.
Please assist in troubleshooting this problem
regards
Salim
01-30-2010 11:28 PM
Has this network performance degredation issue always existed? If no, what has changed? Any "upgrades/downgrades" been performed, routing changes, etc???
Please check basics:
show ip bgp
show ip route
traceroute
show ip cef
show interface
show policy-map interface
If your bgp output (show ip bgp
What is your access type (FR, ATM, Ethernet, etc)? You may need to check if there is any shaping done on your router or provider router)?
Is there a Firewall between your router and the WAN modem?
Please check the above and return with feedback/outputs!
Joe.
02-01-2010 02:05 AM
Hi Salim,
Any updates on your issue?
Joe.
01-31-2010 01:22 AM
hi salim
check the patht he traffic use in both cases and compaire it to see if there are two diffrent routes/pathes or not
please, rate the helpful post
good luck
