Webcast-Catalyst9k
BGP Routing Issues
Hi All,
I am having this issue with one of our customer. The router one is not showing the correct next-hop address as compare to router two.
CE1---->PE1
CE2---->PE2
The existing config is as follows
PE1
interface Loopback1
 description NAT address for web traffic
 ip address 192.168.1.20 255.255.255.255
interface GigabitEthernet0/1
 description xxxx
 ip address x.5.111.69 255.255.255.252
 duplex full
 speed 100
interface Serial1/0.3 point-to-point
 description PVC to CustomerA
 bandwidth 500
 ip address y.6.66.118 255.255.255.252
 ip nat inside
router bgp 65120
 no synchronization
 bgp log-neighbor-changes
 neighbor x.5.111.70 remote-as 65120
 neighbor x.5.111.70 description IBGP to backup router
 neighbor x.5.111.70 next-hop-self
 neighbor x.5.111.70 soft-reconfiguration inbound
 neighbor y.6.66.117 remote-as 13009
 neighbor y.6.66.117 description customerA
 neighbor y.6.66.117 soft-reconfiguration inbound
 neighbor y.6.66.117 route-map HOST out
 neighbor y.6.66.117 filter-list 1 in
ip as-path access-list 1 deny _64500_
ip as-path access-list 1 permit .*
ip nat inside source list 11 interface Loopback1 overload
ip access-list standard HOST
 permit 210.11.66.244
access-list 11 permit ip 10.0.0.0 0.255.255.255 host z.11.66.244
route-map HOST-HOST permit 10
 match ip address HOST
 set as-path prepend 64500 64500
route-map HOST-HOST deny 20
PE2
interface Loopback1
 ip address 192.168.1.21 255.255.255.255
 description xxx
 ip address x.5.111.70 255.255.255.252
 duplex full
 speed 100
 bandwidth 500
 ip address y.6.66.122 255.255.255.252
 ip nat inside
router bgp 65120
 no synchronization
 neighbor x.5.111.69 remote-as 65120
 neighbor x.5.111.69 description IBGP to backup router
 neighbor x.5.111.69 next-hop-self
 neighbor x.5.111.69 soft-reconfiguration inbound
 neighbor y.6.66.121 remote-as 13009
 neighbor y.6.66.121 description customerA
 neighbor y.6.66.121 soft-reconfiguration inbound
 neighbor y.6.66.121 route-map HOST out
 neighbor y.6.66.121 filter-list 1 in
 permit z.11.66.244
The intended result is as follows as showing from router two
PE1# show ip bgp | in 10.16
*i10.16.0.0/16    x.5.111.70          0   100  0 13009 65000 i
PE2# show ip bgp | in 10.16
*>10.16.0.0/16    y.6.66.121          0   100  0 13009 65000 i
I think the customer connection issue will resolve if we can correct the routing in PE1 like as below
*>10.16.0.0/16    y.6.66.117          0   100  0 13009 65000 i
What is required to correct it? Please advice.
Everyone's tags (1)
107
