Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
BGP routing
With router series support routing the whole internet?
thank you
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: BGP routing
Hello Goran,
1) I think you need an EMI = ip services to run BGP on the C3548.
The device should be fine if you accept just two default routes, if you think to receive more you should look at something different with more capabilities in the signalling plane (cpu, memory to host a full BGP table)
2) there are several configuration examples
see
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009456d.shtml
you have your own AS so you have your own public IP prefix(es)
3) probably some changes has to be done in order to secure the device.
at least an access-class to block access from the internet, usage of non default snmp communities and so on
Hope to help
Giuseppe
Re: BGP routing
Hello Goran,
see
Hope to help
Giuseppe
Re: BGP routing
Dear giuslar,
thank you for the quickest responce ever.
that was what i was looking for.
96
