BGP through pix
I have added the necessary static routes, or so I think I have to allow BGP through my pix from outside router to inside router. When I look at the logs I am seeing the following:
Teardown TCP connection 27421004 for outside:<internet router loopback ip>/17404 to outside:<inside switch loopback ip>/179 duration 0:00:00 bytes 0 Flow is a loopback
Is it just me or should the inside switch loopback ip be classified as "inside" and not "outside" by the firewall?? What could I have done wrong to make the pix think this address is outside and not inside?
TIA,
R
1 REPLY
Re: BGP through pix
You need to configure a couple of things on the PIX for BGP traffic to flow through it.
1. Static transalation
2. Access List for outside BGP peer to talk to inside BGP peer - host entry is fine.
Here's a link that will provide the guidance you need to configure the two things noted above. Look under the PIX1 configuration.
http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a008009487d.shtml#pix1
Hope this helps!
Sundar
99
