bgp to 2 providers for isp redundancy, active standby
Hi there
If I have 2 internet providers and my own AS and I want to route to only of them so basically a active standby setup, how would I achieve this ?
say I own the network 195.1.1.0/24 and only want this to advertise this out on one router and the other will be standby, and also for outgoing traffic I want to use the same router!
what config would be best for this ?
Re: bgp to 2 providers for isp redundancy, active standby
Hi there.
This can be achieved by using route maps with AS paths and pre pending.
I use this setup in our call centre.
If you want I can post the relevant config minus ip addressing later if you require it for guidance purposes?
yes the config would be great
however thats for incoming traffic to your AS
how about the outgoing traffic from your internal net ?
Hi there.
Here is the config for router 1, I also have eigrp running between two L3 switches connected to the two routers for users
interface Loopback0
ip address 10.255.2.21 255.255.255.255
interface GigabitEthernet0/0
ip address 10.253.2.89 255.255.255.248
interface GigabitEthernet0/1
ip address 10.254.2.198 255.255.255.252
(External to ISP)
router eigrp 1
redistribute connected
redistribute bgp 65135 route-map SET-TAG-FOR-EXTERNAL-PREFIX
network 10.253.2.89 0.0.0.0
default-metric 100000 1 255 1 1500
no auto-summary
eigrp router-id 10.255.2.21
router bgp 65135
bgp router-id 10.255.2.21
bgp log-neighbor-changes
neighbor 10.254.2.197 remote-as 65530
address-family ipv4
redistribute eigrp 1 route-map DENY-EXTERNAL-PREFIXES
neighbor 10.254.2.197 activate
neighbor 10.254.2.197 soft-reconfiguration inbound
neighbor 10.254.2.197 route-map BGP-INBOUND-FILTER in
no auto-summary
no synchronization
network 10.255.2.21 mask 255.255.255.255
exit-address-family
ip as-path access-list 1 deny _65035$
ip as-path access-list 1 permit .*
route-map BGP-INBOUND-FILTER permit 10
match as-path 1
route-map DENY-EXTERNAL-PREFIXES deny 10
match tag 99
route-map DENY-EXTERNAL-PREFIXES permit 20
route-map SET-TAG-FOR-EXTERNAL-PREFIX permit 10
set tag 99
Router 2
interface Loopback0
ip address 10.255.2.23 255.255.255.255
(External to ISP)
ip address 10.254.2.98 255.255.255.252
ip address 10.253.2.97 255.255.255.248
no ip redirects
no ip proxy-arp
duplex auto
speed auto
router eigrp 1
redistribute bgp 65035 route-map SET-TAG-FOR-EXTERNAL-PREFIX
network 10.253.2.97 0.0.0.0
default-metric 1000 1 255 1 1500
no auto-summary
eigrp router-id 10.255.2.23
router bgp 65035
bgp router-id 10.255.2.23
neighbor 10.254.2.97 remote-as 65530
address-family ipv4
neighbor 10.254.2.97 activate
neighbor 10.254.2.97 soft-reconfiguration inbound
neighbor 10.254.2.97 route-map BGP-INBOUND-FILTER in
neighbor 10.254.2.97 route-map AS-PATH-PREPEND out
no auto-summary
no synchronization
network 10.255.2.23 mask 255.255.255.255
exit-address-family
ip as-path access-list 1 deny _65135$
match as-path 1
match tag 99
set tag 99
route-map AS-PATH-PREPEND permit 10
set as-path prepend 65035
This config stops internal routes from being broadcast to the network but if router 1 dies then router 2 takes over straight away.
Hope this helps.
688
