07-02-2012 06:10 AM - edited 03-04-2019 04:51 PM
I am on the customer side of BGP with my carrier
Looking for the best way to filter the carriers networks(our BGP interfaces and neighbors) from being redistributed from BGP to EIGRP
07-02-2012 06:18 AM
Hi there,
route-maps and prefix lists.
HTH,
Soroush.
07-02-2012 08:33 AM
Soroush - thanks for the reply. I was hoping for a little more info. Anyone have an example or link explaining this a little more?
07-02-2012 09:26 AM
you can control what routes be redistributed into your EIGRP instance from BGP, with route-maps.
you select the routes you want or you dont want to be redistributed with prefix-lists, then using route-maps you call those prefix-lists and Allow or deny them. then you apply the route-map while configuring the redistribution.
example, if i dont want network 172.16.55.0/24 and 192.10.1.100/26 to be redistributed into my EIGRP:
ip prefix-list EIGRP permit 172.16.55.0/24
ip prefix-list EIGRP permit 192.10.1.0/26
route-map BGP_EIGRP deny 10
match ip address prefix-list EIGRP
route-map BGP_EIGRP permit 20
router eigrp 100
redistribute bgp 20 route-map BGP_EIGRP metric xxxx
Also keep in mind to setup appropriate metric for the routes comming from BGP.
useful link: http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a008009487e.shtml#ex2
if you had further questions plz ask
plz Rate if it helped,
Soroush.
07-02-2012 09:49 AM
Soroush - thanks for the explanation. A few questions. on the prefix-list its permit and it gets denied on the route map, is that correct ? Also, is route-map BGP_EIGRP permit 20 to permit all other routes ?
07-02-2012 10:30 AM
yes, for this task you permit network perfixes (based on ur decision) and the prefix-list gets denied in the route-map, then the route-map is assigned to the redistribution process.
route-maps (like access-lists) have an implicit deny at the end. so whenever u r using route-maps to filter routes, you have to have this in mind.
however, if you want to let a few subnets to be redistributed in the EIGRP, i suggest u do the opposite, permit the ones u want and deny all other.
HTH,
plz Rate if it helped.
Soroush.
07-02-2012 10:42 AM
but in this case route-map BGP_EIGRP permit 20 allows everything else ??
07-02-2012 10:55 AM
yes it allowes everything else.
Soroush.
07-02-2012 11:41 AM
Ok - thanks for the info
