Community Member
BGP with VRF-Lite
I have two Catalyst 6500 running BGP between VRF instances. I have IOS 12.2(33)SXH3 on both devices.
Everythings works well, prefixes are exchanged as designed. The only problem I have is that I don't find the right command to see the BGP TCP session state between both Catalyst. The command "show ip bgp summary" does not display anything between devices becaus I don't use the global plane. So, how can I see the same information for each VRF ?
Here is my configuration of one Catalyst:
router bgp 65372
no synchronization
bgp log-neighbor-changes
timers bgp 3 9
no auto-summary
address-family ipv4 vrf FR01RT08
no synchronization
neighbor 10.56.3.29 remote-as 65116
neighbor 10.56.3.29 description * CH01RT07 - Security Z4
neighbor 10.56.3.29 password 7 00331B07107E07150A
neighbor 10.56.3.29 activate
network 10.56.25.0 mask 255.255.255.0
exit-address-family
address-family ipv4 vrf FR01RT02
no synchronization
neighbor 10.56.3.25 remote-as 65116
neighbor 10.56.3.25 description * CH01RT01 - Security Z3
neighbor 10.56.3.25 password 7 01240E054F2E0A1C24
neighbor 10.56.3.25 activate
network 10.56.21.0 mask 255.255.255.0
network 10.56.22.0 mask 255.255.255.0
network 10.56.23.0 mask 255.255.255.0
network 10.56.24.0 mask 255.255.255.0
exit-address-family
Thank you for any help
Yves
Hall of Fame Super Silver
Re: BGP with VRF-Lite
Hello Yves,
you can use
sh ip bgp vpnv4 all summary to get information about vpnv4 and VRF based BGP sessions
note: this release should support also vpnv6 so you need to type the whole keyword (we have almost the same release on several C6500)
Hope to help
Giuseppe
Community Member
Thank you Giuseppe, have a nice day
Yves
474
