Big Problems with Cisco 831
I have a Cisco 831 , and I want to reset it to the factory default. I am able to log into it with hyperlink but I can't seem to get it to do anything. I can't ping it from the network when I set the ip. In fact, after the router restarts the network light goes off, so I figured I messed something up and would just like to reset it like it was out of the box. Any help would be greatly appreciated.
1 REPLY
Re: Big Problems with Cisco 831
Check that you are in enable mode by looking at the prompt. Look for the hash (#) as in Router#
When you are in enable mode, just type:
write erase
confirm with enter, wait till ready and switch the router off and on. You are now back to factory default.
Leo
178
