blank catalyst 3560
I hope someone can please help me, I have a catalyst 3560 series switch that was bought at a auction and the switch did not have the ios installed on it, I was able to get the bin file loaded on it and can get access to it through the console port but from what i have been able to find out about it the switch should have a web interface gui to set it up with please help on getting it installed into the switch, thanks in advance Dan
Hall of Fame Super Blue
Re: blank catalyst 3560
Hi Dan
It depends what you loaded onto the switch. If you loaded just the .bin file then you can only configure if from the CLI.
If you loaded the .tar file then that includes the html pages etc. needed to configure the switch via the web interface.
Jon
How do i load the tar file into the switch is it loaded the same way as the bin file?
Dan
Attached is a link to 3560 configuration document that shows how to upload .tar file to switch.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_see/configuration/guide/swiosfs.html#wp1073579
Jon
110
