Blocking ICMP from WAN on Cisco 3560
I am using Cisco Switch as DMZ Switch. I want to block ICMP packets from internet. Can you please assist me,.
This is what I tried but it didn't work. Do I need to apply this access-list some where ?
ip access-list extended ICMP-CONTROL
remark ***********************
remark ** Permit ICMP Access **
permit icmp host 5.5.5.5 any
deny   icmp any any log
Everyone's tags (3)
1 ACCEPTED SOLUTION
Re: Blocking ICMP from WAN on Cisco 3560
you have to apply the ACL to an interface in in- or outbound direction.
But first you shoud add an permit ip any any because an ACL has an implicit deny any any at the end!
And note that the log option forces a software-processing for those packets, I'd rather leave it out.
Hope that helps
Rolf
Hope that helps
Rolf
but Allowing permit ip any any will open all ports except icmp. That will make device more insecure or I am wrong at any point ?
That's right but I assume that you want to allow some non-ICMP traffic (from 5.5.5.5) too?
I want to allow ICMP only from 5.5.5.5 and block for all.
O.K. but what about non-ICMP traffic?
The ACL you've posted allows ICMP from 5.5.5.5 but nothing else.
No other protocols (IP, TCP, UDP, etc.) from no other sources.
Is that what you want?
Ah, Yes I understand.
And here is working configuration
interface Vlan300
ip access-group ICMP-CONTROL in
permit ip host 5.5.5.5 any
deny   icmp any any
Thanks a lot again.
1450
