Bonded T-1's and 2811
Question is how much bandwidth should we see with a 2811 and an IMA bundle pack (AIM-IMA and 2 dual port VWIC-2MFT-T1.  We are utilizing 3 t-1's in this scenario, so one should expect a 4.5 by 4.5.  But I though I read that the 2811 could only handle up to @ 3.5 by 3.5, and that the 2821 was necessary to gain the max speed?  Is this true?
Hall of Fame Super Silver
Re: Bonded T-1's and 2811
Hello Ken,
if the ATM IMA can handle the three T1 you should be fine. However, ATM IMA has its own overheads so you cannot get 4.5 Mbps of user traffic.
the ATM IMA bundle with 4 E1 is declared supported on C2811 see table 8 in datasheet
https://www.cisco.com/en/US/prod/collateral/routers/ps5854/ps5882/product_data_sheet0900aecd8016fa68_ps5854_Products_Data_Sheet.html
so you should be fine
Hope to help
Giuseppe
There is no theoretical limit (other than the number of ports which you can stuff in) but for 2811, more than 2 T1s would start affecting performance (when used along with other services like access control lists (ACLs), quality of service (QoS), and IP Security (IPSec).
However, for most practical uses, you shouldn't face any issues
Cisco 2800 Series Performance
Platform
Recommended Performance with Services Enabled (IMIX traffic)
Cisco 2801
Up to 1 T1/E1/xDSL
Cisco 2811
Up to 2 T1/E1s/xDSL
Cisco 2821
Up to 4 T1/E1s/xDSL
Cisco 2851
Up to 6 T1/E1s/xDSL
See this
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd80169bd6.html
446
