08-29-2012 10:12 AM - edited 03-04-2019 05:25 PM
We are running two Cisco 3845 routers, one at our central office and one at a remote site. We bonded two T1's together and it worked fine (link 1 and link 2). We now want to add two more T1's and bond the four together but can't seem to get it to work. The original T1's still work fine (link 1 and link 2) but the new ones do not (link 3 and link 4). Here is our config does it look right?
***CENTRAL OFFICE***
card type t1 0 0
card type t1 0 1
card type t1 0 2
card type t1 0 3
card type t1 2 0
card type t1 2 1
network-clock-participate slot 2
network-clock-participate wic 0
network-clock-participate wic 1
network-clock-participate wic 2
network-clock-participate wic 3
network-clock-select 1 T1 0/2/0
network-clock-select 2 T1 0/2/1
network-clock-select 3 T1 0/3/0
network-clock-select 4 T1 0/0/0
controller T1 0/1/0
clock source internal
cablelength long 0db
channel-group 1 timeslots 1-24
controller T1 0/1/1
controller T1 2/0
controller T1 2/0/0
controller T1 2/0/1
interface Multilink1
description Multilink Bundle
ip address 172.19.254.102 255.255.255.252
ppp multilink
ppp multilink group 1
service-policy output LAN-EDGE
interface Serial0/1/0:1
description T1 link 1
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/1:1
description T1 link 2
no ip address
encapsulation ppp
ppp multilink
interface Serial2/0/0:1
description T1 link 3
no ip address
encapsulation ppp
ppp multilink
interface Serial2/0/1:1
description T1 link 4
no ip address
encapsulation ppp
ppp multilink
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
sh ppp multilink
Multilink1
Bundle name: er-VANGPAO-TEMP
Remote Endpoint Discriminator: [1] er-VANGPAO-TEMP
Local Endpoint Discriminator: [1] vgectr01
Bundle up for 3d23h, total bandwidth 3072, load 16/255
Receive buffer limit 24000 bytes, frag timeout 1000 ms
0/0 fragments/bytes in reassembly list
153 lost fragments, 5819169 reordered
142/39549 discarded fragments/bytes, 0 lost received
0xB06B82 received sequence, 0xD182AD sent sequence
Member links: 2 active, 2 inactive (max not set, min not set)
Se0/1/0:1, since 3d23h
Se0/1/1:1, since 3d23h
Se2/0/0:1 (inactive)
Se2/0/1:1 (inactive)
No inactive multilink interfaces
***REMOTE SITE***
card type t1 0 0
card type t1 0 1
controller T1 0/0/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
controller T1 0/0/1
framing esf
linecode b8zs
controller T1 0/1/0
framing esf
linecode b8zs
controller T1 0/1/1
framing esf
linecode b8zs
description Multilink Bundle to Ed Center (AT&T 3Mb)
ip address 172.19.254.101 255.255.255.252
ppp multilink
interface Serial0/0/0:0
description T1 line 1
no ip address
encapsulation ppp
ppp multilink
interface Serial0/0/1:0
description T1 line 2
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/0:0
description T1 line 3
no ip address
encapsulation ppp
ppp multilink
interface Serial0/1/1:0
description T1 line 4
no ip address
encapsulation ppp
ppp multilink
sh ppp multilink
Multilink1, bundle name is vgectr01
Endpoint discriminator is vgectr01
Bundle up for 3d23h, total bandwidth 3072, load 5/255
306 lost fragments, 6783707 reordered
300/184999 discarded fragments/bytes, 0 lost received
0xD18FEA received sequence, 0xB0775C sent sequence
Se0/0/1:0, since 3d23h
Se0/0/0:0, since 3d23h
Se0/1/0:0 (inactive)
Se0/1/1:0 (inactive)
08-29-2012 11:16 PM
Are the Serial interfaces in up/up state? Please attach the "show int", "show version", "show inventory" outputs from both routers.
Kind Regards,
Ivan Shirshin
08-30-2012 06:17 AM
The serial interfaces show down. Below are the sh int, sh ver, sh inv:
vgectr01#sh int s2/0/0:1
Serial2/0/0:1 is down, line protocol is down
Hardware is DSX1
Description: Vang Pao link 3
MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
Encapsulation PPP, LCP Closed, multilink Closed, loopback not set
Keepalive set (10 sec)
Last input 23:02:19, output never, output hang never
Last clearing of "show interface" counters 1w0d
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
220 packets input, 4730 bytes, 0 no buffer
Received 0 broadcasts, 37 runts, 93 giants, 0 throttles
62 input errors, 62 CRC, 0 frame, 0 overrun, 0 ignored, 17 abort
220 packets output, 4730 bytes, 0 underruns
0 unknown protocol drops
5 carrier transitions
vgectr01#sh int s2/0/1:1
Serial2/0/1:1 is down, line protocol is down
Hardware is DSX1
Description: Vang Pao link 4
reliability 210/255, txload 1/255, rxload 1/255
Last input 17:29:05, output never, output hang never
332 packets input, 7138 bytes, 0 no buffer
Received 0 broadcasts, 833910 runts, 2 giants, 0 throttles
1905649 input errors, 1905649 CRC, 0 frame, 0 overrun, 0 ignored, 950859 abort
410 packets output, 9400 bytes, 0 underruns
8 carrier transitions
vgectr01#sh ver
Cisco IOS Software, 3800 Software (C3845-ADVIPSERVICESK9-M), Version 12.4(24)T2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Mon 19-Oct-09 21:46 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
vgectr01 uptime is 1 year, 11 weeks, 4 days, 12 hours, 50 minutes
System returned to ROM by reload at 16:59:42 PDST Fri Jun 10 2011
System restarted at 17:01:01 PDST Fri Jun 10 2011
System image file is "flash:c3845-advipservicesk9-mz.124-24.T2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3845 (revision 1.0) with 482303K/41984K bytes of memory.
Processor board ID FTX1128A37J
2 Gigabit Ethernet interfaces
124 Serial interfaces
11 Channelized/Clear T1/PRI ports
1 Virtual Private Network (VPN) Module
6 Voice FXO interfaces
8 Voice FXS interfaces
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
125440K bytes of ATA System CompactFlash (Read/Write)
vgectr01# sh inv
NAME: "3845 chassis", DESCR: "3845 chassis"
PID: CISCO3845 , VID: V01 , SN: FTX1128A37J
NAME: "c3845 Motherboard with Gigabit Ethernet on Slot 0", DESCR: "c3845 Motherboard with Gigabit Ethernet"
PID: CISCO3845-MB , VID: V06 , SN: FOC112556LQ
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC11260KQ0
NAME: "MFT-EC-64 - 64 Channel Hardware Echo Canceller on Slot 0 SubSlot 0", DESCR: "MFT-EC-64 - 64 Channel Hardware Echo Canceller"
PID: EC-MFT-64 , VID: V01 , SN: FOC1119231D
NAME: "1000BASE-SX SFP", DESCR: "1000BASE-SX SFP"
PID: FTLF8519P2BCL-CS0 , VID: 0000^C, SN: FNS10510RCD
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 1", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC11260LEM
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 2", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC11260MA3
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 3", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC11260KVJ
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC11261D0R
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC11261D55
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 6", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC11261D00
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 7", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC11261D04
NAME: "High Density Voice Module - 8FXS/DID on Slot 1", DESCR: "High Density Voice Module - 8FXS/DID"
PID: EVM-HD-8FXS/DID , VID: V03 , SN: FOC111933R2
NAME: "Six port FXO voice interface daughtercard on Slot 1 SubSlot 0", DESCR: "Six port FXO voice interface daughtercard"
PID: EM-HDA-6FXO , VID: V02 , SN: FOC111933HE
NAME: "High Density Voice2 Network module with on board one port interface on Slot 2", DESCR: "High Density Voice2 Network module with on board one port interface "
PID: NM-HDV2-1T1/E1 , VID: V03 , SN: FOC11376997
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 2 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC11380ZEC
NAME: "PVDMII DSP SIMM with four DSPs on Slot 2 SubSlot 2", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC11374BZB
NAME: "PVDMII DSP SIMM with four DSPs on Slot 2 SubSlot 3", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC11374BZF
NAME: "PVDMII DSP SIMM with four DSPs on Slot 2 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC11374AC1
vgectr01#
***REMOTE SITE***
er-VANGPAO-TEMP#SH INT S0/1/0:0
Serial0/1/0:0 is down, line protocol is down
Hardware is GT96K Serial
Description: T1 line 3
MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec,
Last input never, output never, output hang never
Last clearing of "show interface" counters 4d19h
Conversations 0/0/256 (active/max active/max total)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 carrier transitions
Timeslot(s) Used:1-24, SCC: 0, Transmitter delay is 0 flags
er-VANGPAO-TEMP#SH INT S0/1/1:0
Serial0/1/1:0 is down, line protocol is down
Description: T1 line 4
Timeslot(s) Used:1-24, SCC: 1, Transmitter delay is 0 flags
er-VANGPAO-TEMP#SH VER
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(17), R
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 07-Sep-07 23:03 by prod_rel_team
er-VANGPAO-TEMP uptime is 4 days, 19 hours, 59 minutes
System image file is "flash:c3845-adventerprisek9-mz.124-17.bin"
export@cisco.com.
Cisco 3845 (revision 1.0) with 484352K/39936K bytes of memory.
Processor board ID FTX1140A2L7
8 Serial interfaces
4 Channelized T1/PRI ports
4 Voice FXO interfaces
er-VANGPAO-TEMP#SH INV
PID: CISCO3845 , VID: V01 , SN: FTX1140A2L7
NAME: "c3845 Motherboard with Gigabit Ethernet", DESCR: "c3845 Motherboard with
Gigabit Ethernet"
PID: CISCO3845-MB , VID: V06 , SN: FOC11372RHR
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1", DESCR: "VWIC2-2
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC11380Z6S
PID: SFBR-5766PZ , VID: , SN: AGM125111WW
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC11362XDN
NAME: "2nd generation four port FXO voice interface daughtercard", DESCR: "2nd g
PID: VIC2-4FXO , VID: V02 , SN: FOC11384B93
NAME: "PVDMII DSP SIMM with four DSPs", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC11382ZG9
er-VANGPAO-TEMP#
08-30-2012 07:12 AM
Hello Dtom,
In this case, you will need to isolate the issue. First at all, I recommend performing a hardware loopback test to make sure the new ports are working fine. You can also connect one working T1 to one of the new ports to determine if the interface and T1 controller are coming up. If that happens, probably the issue is related to the provider. On the other hand, I can see that you are participating the data T1s that are part of the multilink and this is not recommended for data circuits for it causes clocking issues. The "network-clock-participate" and "network-clock-select" are used for IMAs and PRIs so I recommend getting rid of those commands related to the cards that are part of the multilink.
Please gather the following outputs for me too:
I request these commands for a previous "show ppp multilink 1" shows lost fragments and this can be caused by the "participate" commands you are using. Thus, I need to check if you are being affected by clocking issues.
Regards.
08-30-2012 08:23 AM
The clock source should be line if the provider is "providing" clocking somewhere in between. Otherwise, one side should be line and the other should use internal. Please check clocking settings before.
09-05-2012 03:29 AM
Hello,,
Pls do HArd Loop back test, but I guess it will fail.
As per the Output of show interface serial at Central Router, the port status is down, check out the cable connectivity at the serial port. As per my experiance the port should not show down untill unless there is any physical connectivity issue. Line Protocol shows down for varius issue at network but not port status.
Rahul Mishra
08-30-2012 08:06 AM
First thing I see, your clock source should not be internal, set it to line at both ends.
08-30-2012 12:21 PM
I will take a look at the clock settings (not very familuar with it thought). I will also move the lines around to see if anything changes. Here is the information requested:
vgectr01#sh controllers t1
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long 0db
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info Firmware: 20090408, FPGA: 13, spm_count = 0
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (673 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
673 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
673 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
86400 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
86400 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 0/0/1 is up.
No alarms detected.
Data in current interval (674 seconds elapsed):
674 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
674 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 0/1/0 is up.
No alarms detected.
Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
Data in current interval (709 seconds elapsed):
T1 0/1/1 is up.
No alarms detected.
T1 0/2/0 is up.
No alarms detected.
Data in current interval (589 seconds elapsed):
T1 0/2/1 is up.
No alarms detected.
Data in current interval (590 seconds elapsed):
T1 0/3/0 is up.
No alarms detected.
Data in current interval (705 seconds elapsed):
T1 0/3/1 is down.
Transmitter is sending remote alarm.
Receiver has loss of signal.
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 705 Unavail Secs
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
T1 2/0 is down.
Cablelength is long gain36 0db
Version info Firmware: 20090408, FPGA: 255, spm_count = 0
Current port master clock:recovered from backplane
Data in current interval (732 seconds elapsed):
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 732 Unavail Secs
T1 2/0/0 is down.
Receiver has remote alarm.
Data in current interval (667 seconds elapsed):
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 667 Unavail Secs
T1 2/0/1 is down.
0 Line Code Violations, 22 Path Code Violations
497 Line Code Violations, 2641 Path Code Violations,
2 Slip Secs, 1 Fr Loss Secs, 0 Line Err Secs, 8 Degraded Mins,
13 Errored Secs, 9 Bursty Err Secs, 1 Severely Err Secs, 85355 Unavail Secs
vgectr01#
vgectr01#sh ppp multilink
Multilink1
Bundle up for 5d02h, total bandwidth 3072, load 88/255
218 lost fragments, 8378853 reordered
202/57474 discarded fragments/bytes, 0 lost received
0x6D69C2 received sequence, 0xC536EB sent sequence
Se0/1/0:1, since 5d02h
Se0/1/1:1, since 5d02h
vgectr01#
vgectr01#sh int multilink 1
Multilink1 is up, line protocol is up
Hardware is multilink group interface
Description: Multilink Bundle to Dakota Campus (AT&T 3Mb)
Internet address is 172.19.254.102/30
MTU 1500 bytes, BW 3072 Kbit/sec, DLY 100000 usec,
reliability 255/255, txload 87/255, rxload 15/255
Encapsulation PPP, LCP Open, multilink Open
Open: IPCP, CDPCP, loopback not set
DTR is pulsed for 2 seconds on reset
Last input 00:00:04, output never, output hang never
Last clearing of "show interface" counters 27w6d
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1118063
Queueing strategy: Class-based queueing
Output queue: 0/1000/0 (size/max total/drops)
5 minute input rate 190000 bits/sec, 180 packets/sec
5 minute output rate 1050000 bits/sec, 241 packets/sec
128764117 packets input, 351983636 bytes, 0 no buffer
2250 input errors, 0 CRC, 543 frame, 0 overrun, 0 ignored, 529 abort
157268319 packets output, 3836912367 bytes, 0 underruns
0 output errors, 0 collisions, 12 interface resets
2 unknown protocol drops
vgectr01#
***REMOTE SITE***
er-VANGPAO-TEMP#sh controllers t1
T1 0/0/0 is up.
No alarms detected.
Version info Firmware: 20070725, FPGA: 13, spm_count = 0
Data in current interval (87 seconds elapsed):
2 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
1432 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1432 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 0/0/1 is up.
No alarms detected.
1 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
1 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
1433 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
1433 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 0/1/0 is down.
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 87 Unavail Secs
T1 0/1/1 is down.
er-VANGPAO-TEMP#
er-VANGPAO-TEMP#sh ppp multilink
Bundle up for 5d02h, total bandwidth 3072, load 16/255
483 lost fragments, 10451510 reordered
473/296250 discarded fragments/bytes, 0 lost received
0xC5869C received sequence, 0x6D9DC7 sent sequence
Se0/0/1:0, since 5d02h
Se0/0/0:0, since 5d02h
er-VANGPAO-TEMP#
er-VANGPAO-TEMP#sh int multilink 1
Description: Multilink Bundle to Ed Center (AT&T 3Mb)
Internet address is 172.19.254.101/30
MTU 1500 bytes, BW 3072 Kbit, DLY 100000 usec,
reliability 255/255, txload 16/255, rxload 83/255
Last input 00:00:00, output never, output hang never
Last clearing of "show interface" counters 5d02h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 766
Output queue: 0/1000/64/766 (size/max total/threshold/drops)
Conversations 0/4/16 (active/max active/max total)
Reserved Conversations 2/2 (allocated/max allocated)
Available Bandwidth 616 kilobits/sec
5 minute input rate 1000000 bits/sec, 238 packets/sec
5 minute output rate 198000 bits/sec, 173 packets/sec
25664477 packets input, 3097761567 bytes, 0 no buffer
956 input errors, 0 CRC, 244 frame, 0 overrun, 0 ignored, 229 abort
24232579 packets output, 331162312 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
er-VANGPAO-TEMP#
08-30-2012 12:48 PM
Hello Dtom,
In this case, we need to take a look at the status of the controllers T1 2/0/0 and 2/0/1. We are observing a remote alarm:
T1 2/0/0 is down.
T1 2/0/1 is down.
This means that the far-end equipment has a problem with the signal. I recommend getting your Telco involved to check if the new T1s were already activated. On the other hand, you can move the line around to gather more evidence if you need to talk to the provider again. Furthermore, it is important to focus on some other details such as clocking (participate commands and clock source) and a potential differential delay issue for there are input errors in the interface multilink while lost fragments were increasing. Input errors in the new T1s would be expected due to the interface status.
Regards.
08-30-2012 12:49 PM
I disagree with Jorge on one point.
If these circuits are physically from your HQ to a Remote, then all timing should be network.
you should only use internal if you are running a back to back link.
08-30-2012 06:27 PM
Jose posting on 'Aug 30, 2012 9:23 AM' is the correct place to start t-shoot on this issue. When you have Point to point links, the carrier should not provide any clocking. One end should be 'line' and other end should be 'internal'. Do that first.
Second- Remove all multilink configs from new T1s and First try to bring up individual T1s. If the T1s still down after 'Clock' adjustment, then check on 'show controllers' and try to run soft loopback tests.
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a00800a754b.shtml
If you have 'hard' loopback plug that would be great. Right away you can prove where the issue is. As this is new T1s- 99.99% its a carrier issue. Push the carrier to send techs to both ends with Test sets. That proves where the issue is.
hth
MS
09-05-2012 11:39 AM
That is not always the case. Altough common in the US, I have seen circuits that provide clock on both ends. Anywhere else in the world, clock is provided to both ends.
09-05-2012 12:26 PM
My own experience (US): Any telco ordered circut (unless specified) even if its point to point will go through a telco CO.
While the circuit is point to point, at the physical layer, it may be comprised of multiple segements. I always take clock from the line.
In some rare cases you just get copper from the telco (LADS circuits). In this case you slave one clock off the line and one clock internal. Haven't done this in years.
09-06-2012 08:11 AM
Three questions:
1) I remove the following statements from tthe central office router:
The "good" t1 line went down. Do I need to do this on both the central office and remote office at the same time?
2) Do you suggest I do the following:
***Central Office Router***
Remove:
On the following interfaces:
S0/1/0:1
S0/1/1:1
S2/0/0:1
S2/0/1:1
Add:
***Remote Site***
Remove:
S0/0/0:0
S0/0/1:0
S0/1/0:0
S0/1/1:0
Add:
clock source line
3) Does anyone know of any good documents that explains clocking (for dummies)?
09-06-2012 08:22 AM
To allow the ports on a specified network module or voice/WAN interface card (VWIC) to use the network clock for timing, use the
command in global configuration mode. To restrict the device to use only its own clock signals, use the
no form of this command.
To allow the ports on a specified network module or voice/WAN interface card (VWIC) to use the network clock for timing, use the network-clock-participate command in global configuration mode. To restrict the device to use only its own clock signals, use the no form of this command. "
So, not a good idea IMHO
try clock source line on everything
http://oreilly.com/catalog/t1survival/chapter/ch05.html
