12-16-2011 09:50 AM - edited 03-04-2019 02:39 PM
I currently have a 2911 router that has a vwic3-2mft-t1/e1 card in it.
I will be receiving a bonded T1 setup from my ISP and I would like to know how I would configure the card to use MPPP.
Desmond
12-16-2011 10:16 AM
Desmond
You will find an example of the configuration in this link:
https://supportforums.cisco.com/message/744628#744628
Rick
12-16-2011 11:33 AM
Thanks for the help Richard!
I do have one issue, after setting up the MPPP interface.
I do not have serial interfaces on this router, I have (2) vwic3-2mft-t1/e1 cards.
How do I configure them?
controller T1 0/2/0
cablelength long 0db
controller T1 0/2/1
controller T1 0/3/0
controller T1 0/3/1
Thanks!
12-16-2011 11:45 AM
Desmond
Try using this command under each of the T1 controller statements
channel-group 0 timeslots 1-24
I believe that configuring the channel-group will create the serial interfaces.
Rick
12-16-2011 12:33 PM
Richard,
Thanks for your help with this, I am able to configure the interface now.
Thanks again!
Desmond
