Bonding Interfaces
I need to bond two T1's and make a 3Mb connection. Can someone refer to me to what commands to use, or an online article or something that will give me an idea of how to do this? Thanks.
1 ACCEPTED SOLUTION
Re: Bonding Interfaces
shivangi you are most wellcome...
and thanks to you also for replying and rating the post.
regards
Devang
hi shivangi,
you can use the Multilink PPP and you can have bundle of T1...following link will help you to configure and understand...
http://www.cisco.com/univercd/cc/td/doc/product/aggr/10000/10ksw/mlppos.htm
rate this post if it helps
regards
Devang
hey devang:
thanks a million for the link...it is really helpful...i won't be able to put into production for a couple of weeks but this is exactly what i was looking for. Thanks again.
regards,
shivangi
regards
Devang
104
